rinsed engine, now stuttering
Old Jul 13, 2005 | 05:27 AM
Gamble-Did-it's Avatar
Default rinsed engine, now stuttering
WTF!!! I washed my turbo ls engine 2 days ago, now it is stuttering. WTF!!! Please help
Old Jul 13, 2005 | 05:38 AM
2lua's Avatar
Default Re: rinsed engine, now stuttering (gamble)
check for water in the spark plug holes, dizzy for mositures.
Old Jul 13, 2005 | 05:46 AM
IHateJDM's Avatar
Default Re: rinsed engine, now stuttering (2lua)
water in the dizzy cap is most likely. When you spray the car next time, put a plastic bag on the intake filter and the dizzy.
Old Jul 13, 2005 | 05:59 AM
fluffydom's Avatar
There's probably condensate in the dist. cap and the spark plug may have gotten wet as well, Dry those off and give her a solid run you should be back on track.
Next time, do what I did, cover the dist., remove all the spark plug wires, I got some rubber bungs that they put on the tips of some furniture that fit PERFECTLY at the top of the spark plug tube, use those to seal off the chamber, wash your engine then blow dry with compressed air, heck even a shop-vac with the hose attached to the blowout end would work.
Check your dist rotor for any oxidation as a result, you may have to change it and the cap.
Old Jul 14, 2005 | 03:59 AM
Thanx all of you. It was water inside of the Spark plug space. I got it all out, and now she's running fine....
THnks again
Old Jul 14, 2005 | 05:36 AM
JDM-EJ1's Avatar
Default Re: rinsed engine, now stuttering (fluffydom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fluffydom &raquo;</TD></TR><TR><TD CLASS="quote">There's probably condensate in the dist. cap and the spark plug may have gotten wet as well, Dry those off and give her a solid run you should be back on track.
This happened to my brother's DA, and we did this and it worked perfectly.
Old Sep 16, 2006 | 11:12 PM
HamiltonRex's Avatar
Default Re: rinsed engine, now stuttering (JDM-EJ1)
Im glad i found this thread..
Believe i have same problem.. Ill check in morning, thanks HT!
Old Sep 17, 2006 | 12:17 AM
hatch96y7's Avatar
Default Re: rinsed engine, now stuttering (HamiltonRex)
u coul dgo to autozone and they have some spray i forgot the name of it but it drys off the water u just spray it in all the places u think its wet and let sit then hit vtec
or next time let ur car cool down all the way then start it then wash and nothing will go wrong works everytime.
v8killaz
Feb 26, 2011 03:40 PM
PaChiLa Leader
May 8, 2008 05:05 PM
Silver_lude
Mar 15, 2007 12:39 PM
.Kevin.
Aug 25, 2005 06:46 AM
pr0jektdc2
Nov 27, 2004 07:19 PM
