Witch cam should i chosse?
My setup is as follows:
B16A2
4-1 Header
Blox intake
Custom throttle body
2" custom high flow exhaust system
K/N open air intake
When i change cams i will also change, valve springs to Skunk2, get better compession don't know how much thou.
Is there anything else i should change to get some power out of the new cams?
Have thought about the BC III cams but idon't know.
The car is mainly for the street.
Know that this has been asked many times, but i want to get an opinion specific to my engine.
Hope you understand even if my english is not so good.
B16A2
4-1 Header
Blox intake
K/N open air intake
well vteckidd just did a stockblock b16 with omnipowerflat faced valves, m22's and a aebs IM and there doing 170whp untuned
why skunk2 valvetrain tho...?
they put flat face valves to bump up the compression by like .2-.4cr thats about it..yeah check out http://www.m24x.com for more info on the m22's
$$$ CAM GEARS, CAMS, VALVES, SPRINGS, RETAINERS, THROTTLE BODIES, INTAKE MANIFOLDS & MORE-SKUNK2 $$$
LSD_Motorsports
Performance
194
Feb 2, 2011 10:54 AM
boostedprelude
Nov 7, 2005 10:29 AM
INVRSDITWLDBEZ
Jan 25, 2004 06:53 PM
