portflow inner springs on intake and portflow inner springs on exh
i was wondering if its ok to do that. i want to maybe run skunk2stg3 cams on a b16a1 with ctr pistons. let me konw
I have portflow stiff inners on intake and exhaust and type r's on the outer springs with portflow titanium retainers portflow said the valve train will be good up to 10,200rpm and jun said that they prefer the jun valve train but portflow will work fine with there cams.
If you are going to run stock reatiners with Stg.3's check the retainer to valve seal clearance. As far as springs listen to all the people her that have tried all the combos, or call Portflow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asocallocal »</TD></TR><TR><TD CLASS="quote">can i do this? i want to maybe run some big cams like jun3 or skunk2 stg3. </TD></TR></TABLE>
Well first of all a Jun 3 is not comparible to a Skunk Stage 3, as you can see the Stage three has alot more lift
Jun Type 3 12.0 mm, duration - 265.3 @ 1mm 11.5 mm, duration - 265.3 @ 1mm
Skunk2 stage 3 12.8 mm, duration 273 @ 1mm 11.5 mm, duration 273 @ 1mm
Second of all everyones advise that states that they will be good to X,XXX amount of revs is retarded. Springs are good up to a certain amount of lift. If you plan on using portflow inner springs with ITR yellow outers you can handle up to 12.5mm lift on both sides. Thus by looking at the specs above, You can handle Jun3's no problem but not Skunk Stage 3's. i recomend running skunk Stage 2's or Buddy club Spec IV's if you plan on using 11.5:1+
Skunk2 stage 2 12.3 mm, duration 266 @ 1mm 11.8 mm, duration 262 @ 1mm
Buddy Club IV 12.3mm, duration 306@1mm 11.8mm, duration-302@1mm
ok, what about the stock retainer GUILOTINE. what is the specs that the stock b16 retainer can handle?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asocallocal »</TD></TR><TR><TD CLASS="quote">ok, what about the stock retainer GUILOTINE. what is the specs that the stock b16 retainer can handle?</TD></TR></TABLE>
Buy titanium retainers. they only cost like $150 and can withstand more spring pressure from aftermarket springs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asocallocal »</TD></TR><TR><TD CLASS="quote">will stock retrainers break?</TD></TR></TABLE>
Yes, they have been known to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asocallocal »</TD></TR><TR><TD CLASS="quote">what cams can stock retainer handle? do retainers really matter, will stock break?</TD></TR></TABLE>
if you bump the reve limiter alot thent eh stock steel retainers WILL crack and break.
Greg
Greg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asocallocal »</TD></TR><TR><TD CLASS="quote">what is alot? can it handle 9k or 9.5k?</TD></TR></TABLE>
like doing burnouts and pounding against your rev limiter ... thats alot.
do you think skunk pro 1 cams will work reliably with portflow inners and itr yellow outers? i'm running OEM ITR retainers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oldskool teggy »</TD></TR><TR><TD CLASS="quote">do you think skunk pro 1 cams will work reliably with portflow inners and itr yellow outers? i'm running OEM ITR retainers</TD></TR></TABLE>
pro1's and portflow springs and retainers in my car, no problems at all. Do not use your oem retainers get a good set of ti retainers, its cheap insurance
jeremy.
15
Apr 19, 2005 03:21 AM
austrian type-R
Jul 9, 2003 02:27 PM
StinkyTofu
Feb 8, 2002 10:17 AM
Black R
Jun 15, 2001 06:58 AM
