Spoon N1 Questions
Old Feb 16, 2002 | 05:30 AM
Jim80y's Avatar
Default Spoon N1 Questions
Already did a search. Just a few questions about the Spoon N1 axle-back, since when did it change from a 60mm pipe to a 63mm pipe? And with the newer version (63mm) will this bolt up straight to the factory b-pipe?
On the ITR, are there more than two hanger holes? What I mean to ask is can the muffler be moved up or down on different hanger holes to prevent the muffler tip from touching the bumper?
Old Feb 16, 2002 | 06:57 AM
01YellowITR's Avatar
Default Re: Spoon N1 Questions (Jim80y)
I got the newer one and it is bolt straight up with the factory pipe (2.25 ines)
For the hanger holes, there are only two holes you can move up and down with a little bit of space(at least what i did in mine) You don't want to move it up since it would heat up your bumper.
Hope this is helpfull
Old Feb 16, 2002 | 07:34 AM
Mike M's Avatar
Founding Member
Default Re: Spoon N1 Questions (01YellowITR)
Bolts up fine, they switched to 63mm about 6 months ago.
It sits perfect and doesn't burn the bumper No need to move it up or down.
Old Feb 16, 2002 | 10:11 AM
BryanSprinkel's Avatar
Default Re: Spoon N1 Questions (TypeRmsm)
I have an old one and it fits fine as well....
Bryan
Old Feb 16, 2002 | 11:54 AM
EGtoR's Avatar
Default Re: Spoon N1 Questions (BryanSprinkel)
What's the point of having a 63mm muffler when the b-pipe is only 60mm?
It just like having a USDM collector header and run a 2.5" exhaust system, how stupid is that?
Old Feb 16, 2002 | 01:41 PM
Rob :190:'s Avatar
Default Re: Spoon N1 Questions (EGtoR)
well maybe someone (me) would get the axle back first, and not want to have to buy two mufflers if they need more flow down the road for cams, etc......
PS-Mike, you mentioned a possible group buy on the N1s a while ago, any chance of this?
Old Feb 16, 2002 | 02:46 PM
Mike M's Avatar
Founding Member
Default Re: Spoon N1 Questions (Rob1035)
Most likely End of the month I will have something up, Just finishing 4 other GB's I have going right now
TastyDragon
Mar 8, 2008 10:22 PM
dropd4door
Dec 7, 2003 08:48 PM
skafia
Jan 7, 2003 11:12 PM
poo flinger
Nov 13, 2002 10:23 PM
skafia
Aug 7, 2002 02:49 PM
