FS: bunch of EK parts off my 99 hatchback
Testing waters right now to see if anyone's interested in the parts off my car.
All prices OBO, but no lowballing.
Located in Seattle. Shipping will be extra.
Si OEM lip unpainted black. Has a few scratches and nicks here and there. $80
Si OEM grille painted trim black color. $60
Si OEM shift **** and boot. Numbers have been worn off at the top. Still looks good. $30
Si OEM rear swaybar with endlinks, bushings, d-brackets, everything needed to install on a 96-00 Civic. $90
GSR OEM front strut tower bar. Top of bar is painted wrinkle black. Looks good and matches black wrinkle coated valve covers. $25
96-00 hatchback carbon fiber duckbill. Quality is top notch. Mint condition. Fittament is good. $180
GSR blades with stock michelins. 3 rims have minor scratches and nicks here and there. One has a long curb half way around the lip. Tires have about 40% left. $280
Ground Control coilovers for 92-00 civics. Comes with sleeves, springs, perches, urethane top mounts. Used for a 6 months after buying them used from another user. $150
KYB AGX for 96-00 civics. 4 way adjustable in the front and 8 way in the rear. Less than a month old with boxes. $260
97-01 CR-V cluster. Automatic, lights up orange. Plug and play with 96-00 Civics. $50
00 Civic Ex stock exhaust manifold. Clean, looks like the JDM ITR 4-1 at the top. One of the best if not the best stock D series exhaust manifolds. Works perfectly with the two items below. $40
92-95 Ex coupe stock mid pipe. Works great on 96-00 CX/DX coupe or hb when used with the cat below and header above. $30
99-00 Si stock cat. In good condition. Will bolt up to a 96-00 DX/CX coupe or hb when used with the mid pipe above and header. $60
Modified by chowmien at 12:11 AM 7/13/2005
bblkraz33
Apr 20, 2015 05:44 AM
ek92
Northwest (Sales)
Apr 2, 2011 05:15 PM
Bump for you
