cluth help
Old Jul 12, 2005 | 09:18 PM
arcticjay's Avatar
Default cluth help
I have a cbr 600 f2 and I am tring to get the locknut off but it will not move in any way can any one help.
Old Jul 12, 2005 | 09:37 PM
marmaladedad's Avatar
Locknut? Which one? You need to be more specific.
If you are referring to the rear wheel locknut, then you'll need to use the included wrench in the toolkit (or a socket) to hold the other side of the axle steady. The rear wheel needs somewhere between 50-80 lb-ft of torque (I don't have the exact # with me).
Of course, if you're removing the wheel, this should be done with the rear wheel off the ground with a rear stand or motorcycle jack.
Old Jul 13, 2005 | 03:55 AM
cbrman's Avatar
Default Re: cluth help (arcticjay)
Are you talking about the nut in the center of the clutch hub?
If you notice there is a spot that has been punched in to lock the nut in position. (Prevent the nut from spinning.) I took a flathead screwdriver and bent the indented part on the nut back out so you can remove it.
What are you trying to do replace the clutch? Install a shift kit?
Do you have the special tool needed to hold the pressure plate stationary while you remove the 4 bolts?
I created a homemade tool because I didnt want to wait for honda to order one for me.
If you need, I can dig up the pics of it.
Steven
spoon.ef9
16
Jan 25, 2012 04:18 PM
HondaKing90
Aug 30, 2010 09:20 AM
SIRIUS
Honda Civic (2001 - 2005)
Aug 21, 2007 11:15 AM
Freddy2121
Honda Motorcycles
Jan 7, 2007 05:46 PM
mattymatt
Jan 23, 2002 10:04 AM
