FS: Fresh Full Built LS/VTEC Engine Package. NorCal
Fresh Full Built LS/VTEC Engine Package. NorCal. 2000 miles.
210whp / 140wtq on a 1.8L B-series LS/VTEC Engine.
It ran 12.9 @ 106 in my 2001 Integra. (Will run faster in a lighter car. ie, EG)
Have video clip / dyno sheet / time slip to show.
OBD1 B18A Block
*Endyn RollerWave Pistons 81.5mm
*Shotpeen LS rods; lighten and balanced
*ARP rod bolts
*All machine work done on block (bore hone deck)
*Micropolished Crank
*All new seals/pumps and even oil pan. All parts were bought new.
*OEM headgasket. New timing belt. Water Pump (All OEM Type R from Acura)
PR3-2 B16A Head (2nd gen)
*Multi-Angle Port and Polish
*Skunk2 Stg II cams
*Ferrera S/S valves.
*Crower dual valve springs
*Crower tit. retainers
*Ported Civic Type R IM (Endyn Port Style)
*Civic Type R TB (Match Ported)
*All new seals.
*ARP head bolts
Civic Type R Tranny with JDM 4.785FD bought from a well known H-T member.
*Clutch Master Stage 4 clutch kit (all bought brand new)
*Lighten and balanced Type R flywheel
*no grinds or slips. Tranny is like new.
In addition to the engine + tranny, it also includes
Custom 4-1 Header
Hondata S200 Tuned to 210whp/140wtq with P28 chipped.
AEM Fuel Rail & Adj. FPR
RC 310CC Injectors. High Flow Fuel Pump.
Type R engine mounts with ES Inserts
Wiring Harness
New Dist.
Shift Linkage
New Axles
Any necessary parts that completes a full swap will be included.
You will need nothing else. 95% of the parts were bought brand new
with receipts. The only parts were bought used were the short
block, cylinder head, and the tranny.
This engine makes 210whp and 140whp. Dyno by DSR (Dyno Spot Racing) in San Jose, CA. The shop can vertify the engine and its horsepower.
Spent over $9,000 total street value. I went all out on this one and wanted
to keep 1.8L and achieve 12s in my Integra and now I have done it so I
want to sell this engine and move onto to my next project. I am asking
half of what I spent, which is $4,500 and the price is still OBO.
If you live in NorCal, this engine can be professionally installed for $500.
If you do not live locally, this engine can be shipped to your door only for a few
hundred dollars.
EDIT: Please email me for faster response. My email is f12ank622@sbcglobal.net
I will consider parting this package out in only 3 sections: complete short block,
complete top end (head), complete tranny with clutch kit. If you only want
1 single part off the engine, I will -NOT- do that. Thanks.
OBD1 B18A Block
*ARP rod bolts
*Skunk2 Stg II cams
*All new seals.
*ARP head bolts
Custom 4-1 Header
Wiring Harness
New Dist.
Shift Linkage
New Axles
hundred dollars.
BrokenLimits
24
May 12, 2004 05:41 PM
