Suspension & Brakes Theory, alignment, spring rates....
Traction Bar - VS - Stock Front Crossmember
Old Jul 12, 2005 | 06:56 PM
EFRue57's Avatar
Default Traction Bar - VS - Stock Front Crossmember
I was wondering which I should use. Right now I have the place racing front cross member and it's already bent. So I'm gonna trash it but need to know what to buy next.
I don't plan on doing much drag racing, mainly road racing. Does removing the front crossmember to replace it for a traction bar create more chassis flex? Are the front crossmembers more solid to help stiffen up the chassis? Or are the traction bars just as good?
Basically what I need to know is a traction bar a good investment if I want better suspension while going through turns or should I just stick with the stock one and just use polyurethane bushings? I would like opinions by people who have used both. Thanks.
Old Jul 13, 2005 | 09:54 AM
Dirk-EG's Avatar
Default Re: Traction Bar - VS - Stock Front Crossmember (EFRue57)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFRue57 &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering which I should use. Right now I have the place racing front cross member and it's already bent. So I'm gonna trash it but need to know what to buy next.
For the EF chassis Jimfab makes some nice *** traction bars, with the engine mount on it.. Its better then stock, because its without the bushings in front, I drive my full-race bar daily and love it.... I'd say if its busted, buy something bettr while you are at it.
K-Spec
Nov 20, 2007 10:55 AM
2point6
Sep 19, 2007 12:00 AM
crxss outhe eyes
Suspension & Brakes
May 1, 2007 06:17 AM
b18sihatch
Aug 14, 2006 12:07 PM
EFRue57
Jul 12, 2005 07:43 PM
