What are the symptoms of a bad fuel pressure regulator?
Old Jul 12, 2005 | 06:50 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Default What are the symptoms of a bad fuel pressure regulator?
What are the symptoms of a bad FPR?
Old Jul 13, 2005 | 06:27 AM
JimBlake's Avatar
Default Re: What are the symptoms of a bad fuel pressure regulator? (^^whatnoobsearchthenGTFO)
Depends on how it failed. Sometimes the diaphragm tears, then you get fuel in the vacuum line. Otherwise, you get incorrect fuel pressure in the rail.
Old Jul 13, 2005 | 08:18 AM
Rustydog's Avatar
As said, your going to be getting either to much, or too little fuel pressure, resulting in the car running rich or lean. You need to watch a fuel pressure gauge whilst driving really to be able to diagnose it.
Old Jul 13, 2005 | 11:34 AM
GS-Rcivic's Avatar
Default Re: (Rustydog)
not to jack this but.. i might have this problem also. Adjusting the B&M regulator, i see no movement on the gauge, stays at 50psi, can this be a bad relulator or gauge?
Old Jul 13, 2005 | 12:51 PM
JimBlake's Avatar
Default Re: (GS-Rcivic)
Use your gauge on someone else's car to check whether the gauge is busted...
Old Jul 13, 2005 | 01:14 PM
slomofo's Avatar
GDD Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GS-Rcivic &raquo;</TD></TR><TR><TD CLASS="quote">not to jack this but.. i might have this problem also. Adjusting the B&M regulator, i see no movement on the gauge, stays at 50psi, can this be a bad relulator or gauge? </TD></TR></TABLE>
Probably a bad installation job, the B&M requires the use of the modified stock regulator, u probably did it wrong and fucked up.
Old Jul 13, 2005 | 01:31 PM
GS-Rcivic's Avatar
Default Re: (slomofo)
I bought it alredy done up, it was a working unit. The gauge is kinda wiggling, the casing around it so im thinking maybe its the gauge.
chrisb
May 9, 2005 07:06 PM
spidermancivic
Feb 23, 2005 09:48 AM
shadykit
Dec 30, 2004 12:29 PM
