hwo to fix up rear interior??
I just remembered that i have a rear trunk cover but its split in half...i was wondering what i can do to fix it up so both pieces will be able to stay together again???any help would be appreciated and please no jerky *** flaming comments from some of you ppl...thanks
i have one already but its split in half...i dont want a new one....i just want a write up or something explaining how to fix it...u know the two pieces instead of one piece
when mine split i went to the hardware store and got a hinge long enough to cover the whole length. and bolted it underneath to both pieces using allen bolts. works like a champ
Mine is like this too but I haven't bothered to fix it yet. I just run the car without it. However with a little ingenuity and a trip to the hardware store it should be an easy fix. You could always put some carpet on some plywood and make your own.
the long hinge is called a piano hinge.
you could use a piano hinge, or i used door hinges mounted to the underside, but first i painted them and the screws black so you don't see them.
i dont have pictures.
the hinge is 3/4" wide total. its as long as the rear cover and i have 18 1/4" allen bolts honding the covers to hinge 9 on each side. i will try to get some good pictures of it
b.d.racing
12
Jan 15, 2008 04:28 PM
Iron_Forrix
Oct 7, 2006 07:02 AM
W O T
May 1, 2006 04:28 AM
litterbox
45
Nov 15, 2005 10:54 AM
