Why is car sliding around corners?
Old Feb 15, 2002 | 09:52 PM
cbrf-3's Avatar
Default Why is car sliding around corners?
Heres my setup
Koni adj's
eibach pro-kit
full energy suspension kit
z-10 radius rods
195-50-15's with bridgestone potenzas S0-3 pole positions
upper neuspeed bar
car is all within specs
This car is sliding through the corners not even at that high of speed and
theres no tire screeching just starts sliding like the car is on dirt or
something. Also the car doesnt even feel tight though the corners at
all. I know its not the tires cuz those pole postions are suppose to be
pretty kickass. Do i need stiffer springs or something to put those tires
on the ground tighter?
let me know if you need more detail guys.
Old Feb 15, 2002 | 09:54 PM
seek167's Avatar
Default Re: Why is car sliding around corners? (cbrf-3)
they might be to stiff . tone it down a bit
Old Feb 15, 2002 | 11:56 PM
McLaren's Avatar
you need wider tires.
try 205/50 15, 195 is just don't give you enough grip.
Old Feb 16, 2002 | 03:02 AM
mr tl's Avatar
i would have to say tires. when i have put my old tires on i get that sliding feeling. when i put my good tires on i get the grippy feeling. go wider
Old Feb 16, 2002 | 07:37 AM
89HF's Avatar
New User
I think it's your Energy bushings master kit,myself.
Old Feb 16, 2002 | 01:29 PM
JeffS's Avatar
By sliding, do you mean the front, rear, or the entire car at once?
Old Feb 16, 2002 | 04:47 PM
Stephen's Avatar
Default Re: Why is car sliding around corners? (JeffS)
Your shocks may be a little stiff for the road you're on.
Whenever I had a problem with the front or rear sliding, I softened the shocks till it stopped.
wtsapexipowerfc
Apr 27, 2011 07:26 AM
Torontodude
Dec 30, 2007 12:42 PM
VTEC IS UR BEST FRIEND
Suspension & Brakes
May 24, 2007 05:02 AM
mnaines
Nov 30, 2006 11:35 AM
TSAngry
Feb 26, 2006 05:48 PM
