HELP !!!!!Dont know what is wrong wit my turbo ej1?
Old Jul 12, 2005 | 11:14 AM
TurbodEG's Avatar
Default HELP !!!!!Dont know what is wrong wit my turbo ej1?
ok so here it goes... I have some problems wrong wit my car and i dunno what they are.... Whenever im driving the car seems to hesitate aroung 2 to 5 rpm.... jus for a second but still it gets annoying after awhile.. I changed the spark plugs, and the fuel filter and it seemed to make a difference but it came back again..
The other problem is when i brake i hear a deep cracking noise when im comming to a stop..I think it might be the axles but im not sure and want to get others opinions before i start doin ****...
Thanks for ur helps... Latz
Old Jul 12, 2005 | 11:17 AM
Stoich EG2's Avatar
Default Re: HELP !!!!!Dont know what is wrong wit my turbo ej1? (TurbodEG)
check your throttle cable for looseness? timing could be off just a bit.
WHAT YEAR, MODEL, ENGINE, ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC ETC
Did you try checking your brake pads or calipers for that cracking noise? it could also be a loose bolt/nut somewhere in the suspension area that has a lot of stress on it
Old Jul 12, 2005 | 11:25 AM
EG-Kaos's Avatar
i used to drive a 94 tsi talon and i had the same problems... well besides the cracking, o yea for tha cracking its a good place to start at the axles, aslo make sure u take a look at the suspension because that would also be it.
Old Jul 12, 2005 | 12:39 PM
TurbodEG's Avatar
Default Re: HELP !!!!!Dont know what is wrong wit my turbo ej1? (Advan06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Advan06 &raquo;</TD></TR><TR><TD CLASS="quote">check your throttle cable for looseness? timing could be off just a bit.
Did you try checking your brake pads or calipers for that cracking noise? it could also be a loose bolt/nut somewhere in the suspension area that has a lot of stress on it</TD></TR></TABLE>
Its a 95 civic with b16a motor.. T3/Te04 turbo setup at 6 psi..I jus changed the rotors and pads with new onesl. Maybe i forgot to bolt a screw down all the way tight.... ****.........
Old Jul 12, 2005 | 04:09 PM
Mario.'s Avatar
Default Re: HELP !!!!!Dont know what is wrong wit my turbo ej1? (Senses Fail y0!)
Check your cap and rotor.
TTTuner
Dec 29, 2015 08:43 PM
XXXRacing
May 23, 2010 07:15 AM
