Does your 91' accord stall in the heat?
Old Jul 12, 2005 | 10:34 AM
daver_boy's Avatar
Default Does your 91' accord stall in the heat?
Hi Guys,
I've been reading a lot of threads where people have cars that won't start in the heat. Well until a day ago I was in the same boat (car ) After reading and doing a lot of research I found that the main relay is most likely the culprit. So I called the Honda dealer to price out a new relay ($83CND) so I figured I would pull it out and try fix it myself. So sure enough I pulled the relay and checked the solder joints. Two or three of the joints were 'cold' soldered. So I re-soldered them, replaced the relay, and bingo bango never stalled in the heat again!!!
So for all of those in the same situation I hope this helps you out! Ask for ANY questions!!
Dave
Old Jul 12, 2005 | 11:43 AM
James's Avatar
Default Re: Does your 91' accord stall in the heat? (daver_boy)
lucky you. I had to shell $$ and replaced mine a couple years ago.
Old Jul 12, 2005 | 11:46 AM
daver_boy's Avatar
Default Re: Does your 91' accord stall in the heat? (James)
That sucks! I saved the $ thanks to this forum. I just hope it'll help do the same for someone else!
andy9279
May 4, 2016 04:34 PM
Juan_Mitosis
May 28, 2009 07:23 AM
romeoz24_2000
Aug 12, 2008 04:03 AM
TypeRobert
Oct 19, 2007 07:07 PM
alwaystheking43
Jul 5, 2007 10:48 AM
