Need help with CRX koni/GC setup
I own a 91 CRX Si. with that being said....
I found an awesome deal on a set of koni yellow/GC coilover setup for a 88 crx.
now, I know I need the 88 civic/crx rear LCA for them to work, but I have also heard that the 89 LCA can be used also. Can I retain my factory front LCA?
would any 88civic/crx LCA be compatible with the remaining 91CRX Si componenets? (swaybar etc.)
Also, what all would I need to make this work?
TIA!
TIA!
you would need the 88 Si LCA, or you can use the ITR rear LCA to retain a sway bar...
dont worry about the fronts, they are the same...
