Difference between 92-95 civic and 90-93 integra shocks?
92-95 EG shocks would be comparable to 94-00 DC shocks. they have the same shock diameter. probably different lengths.
88-91 EF and 90-93 DA shocks have the same shock diameters which is smaller than EG/DC, but different lengths from each other. the EF is shorter.
That is correct. However, the rear shock forks are exactly the same dimensions, so DA/EF/EG/DC shocks will all bolt to the rear LCA fine on any of those cars (except the ITR and 88 CRX). The fronts, because the DA/EF are narrower, will need EG/DC front forks to run EG/DC shocks, while running the DA/EF shocks on an EG/DC chassis would require DA/EF front forks.
724chris
Dec 16, 2009 10:47 PM
