Worn Vtec Lobes on ITR cams
Old Jul 11, 2005 | 08:11 PM
flat-blk-HB's Avatar
Default Worn Vtec Lobes on ITR cams
What would cause only the Vtec lobes 2 out of 4 on the exhaust cam to flatspot on the tip? Sticking LMA's? It is only on the Vtec lobes not the others, so I was thinking it would not be the valves be adjusted to tight..
I got the cams from a friend who got them from somebody esle so as far as we know they have not been ran like this in a while.
After taking a second look it is the intake cam that is flat-spotted not the exhaust...
Modified by flat-blk-HB at 6:04 PM 7/17/2005
Old Jul 11, 2005 | 08:24 PM
sheepey's Avatar
coil bind bud..
Old Jul 11, 2005 | 08:27 PM
Default Re: (sheepey)
I just got off the phone with him (the oringnal owner of the cams) and he said he had dropped a valve in his GSR head with these cams....
The intake cam looks good so I should proably just keep my GSR exhaust cam in there..(b16a head with CTR valvetrain dual springs on both sides)..Will just changing the intake cam be worth it..They are the older USDM ITR cams..not the ones like the CTR
Modified by flat-blk-HB at 11:41 PM 7/11/2005
Old Jul 12, 2005 | 08:19 PM
mportbusta's Avatar
Default Re: Worn Vtec Lobes on ITR cams (flat-blk-HB)
2 words.....Vtec Killer
Old Jul 12, 2005 | 09:51 PM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheepey &raquo;</TD></TR><TR><TD CLASS="quote">coil bind bud..</TD></TR></TABLE>There is no way in the world you can coil bind a spring with an ITR cam, even a stock spring. There is not enough lift in that cam.
A flat cam will definitely drop valves, however.
Old Jul 13, 2005 | 04:11 AM
Default Re: (earl)
thanks for the input
Fink29
368
Jul 6, 2012 12:08 AM
gsrsuperman
Jul 3, 2010 12:44 PM
ferio 95
Jan 26, 2005 06:43 AM
i HAVEtheADVANtage
May 15, 2003 04:43 PM
skunked
Dec 12, 2002 10:01 AM
