will 96 itr suspension fit on an 88 crx?
Old Jul 11, 2005 | 08:10 PM
N_A_is_best's Avatar
Default will 96 itr suspension fit on an 88 crx?
will complete 96 itr suspension fit on a crx and if soo how much work does it entitle? thx
Old Jul 11, 2005 | 08:40 PM
Andy R's Avatar
Default Re: will 96 itr suspension fit on an 88 crx? (N_A_is_best)
you can take the rear trailing arm with hubs/rotors/calipers, but keep the crx upper/lower control arms and compensator arm. I think if you use the teg lca, you will have to use the teg sway bar, but the hub will stick out about a 1/4" on each side and neg camber will be increased. Could cause wheel well rubbing issues as well as tire wear. I'm not completely sure about the front, so i'll let someone else chime in on that.
Old Jul 11, 2005 | 11:30 PM
FlatBrokeHatch's Avatar
Default Re: will 96 itr suspension fit on an 88 crx? (Andy R)
Almost 100% positive the itr and eg fronts are interchangeable...and I know the eg fronts do not fit on efs.
Old Jul 12, 2005 | 03:08 PM
thank you for all the insight anyone else have any idea about this or a step by step
Old Jul 12, 2005 | 03:23 PM
Rednas's Avatar
ask (Wu Tang) he has the same set up in his crx he should be able to explain it better than most people.
Old Jul 12, 2005 | 03:24 PM
Tyson's Avatar
what part of the ITR "suspension" do you want to use? shocks? control arms? knuckles?
Old Jul 12, 2005 | 03:34 PM
2point2's Avatar
get rid of the avatar kid.
Old Jul 12, 2005 | 04:47 PM
wu tang's Avatar
Default Re: (2point2)
looks like another 96 suspention question. lol
for the front. USE ONLY the knuckle. thats it. everything else you need EF ( as in lower control arm, keep your steering arm and keep you upper control arm) . for the rear. its like doing rear disk. its super easy!
heres a pic
Old Jul 12, 2005 | 04:49 PM
Default Re: (wu tang)
sweet all of the rear just swaps over though right e-brake cables and all
Tyson's Avatar
hmmm something looks very wrong with your wheels not being centered in the wheel wells...
Old Jul 12, 2005 | 04:52 PM
wu tang's Avatar
Default Re: (Tyson)
its the angle of the pic evreything sits fine
Old Jul 12, 2005 | 04:58 PM
does the rear only fit on the 88's?
Old Jul 12, 2005 | 05:46 PM
XJamesX's Avatar
Default Re: (N_A_is_best)
No the rear will fit on all crx's. Like wutang said its like swapping over any rear discs from another compatible honda. If you are talking about the 88 crx Lower control arms then you will need the shocks to fit those control arms. The 88 crx's and the type R's have the same LCA's.
Wu tang if a car with the R knuckles isn't lowered as much as your car will there be positive camber? What I mean is that if a crx with R Knuckles was at stock height there will be + camber and as it is lowered the camber will become negative. As with lowering any car the camber becomes -. Am I right in assuming that.
-James-.
Old Jul 12, 2005 | 06:00 PM
wu tang's Avatar
Default Re: (B18C5crx)
yes james, the meth of postive camber is very true. if your not slammed your fucked. rigth now i have 0 camber on my wheels. thats how low u need to be to not have postive camber
Old Jul 12, 2005 | 06:03 PM
wu tang's Avatar
heres another pic
to show the front rim
Old Jul 12, 2005 | 07:53 PM
silentdork818's Avatar
newb here...
what about axles? can you use your stock ones? the itr's use 36mm axles.
Old Jul 12, 2005 | 09:59 PM
Chase's Avatar
Default Re: (ef four door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wu tang &raquo;</TD></TR><TR><TD CLASS="quote">
]</TD></TR></TABLE>
Is this the same for 5-lug itr suspension/brakes??
Old Jul 12, 2005 | 10:43 PM
wu tang's Avatar
Default Re: (b16crxkid)
for sure man. the only differant between 96 spec to 97-01 is how many lugs u got
Old Jul 22, 2005 | 06:43 AM
cmyrex's Avatar
is there a way to do this without slamming the car?
Old Jul 22, 2005 | 07:19 AM
fireant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wu tang &raquo;</TD></TR><TR><TD CLASS="quote">looks like another 96 suspention question. lol
Looks like you've got no caster there.
Old Jul 22, 2005 | 08:31 AM
BiG Chris's Avatar
i cant wait to get my 5lug done its alot of work but i plan to share it with you all when i get it done but i dont plan to have it done till after jgtc
Old Jul 22, 2005 | 08:39 AM
Outsane's Avatar
wheel base looks like it went from 96 inch to 90...
Old Jul 22, 2005 | 08:41 AM
Outsane's Avatar
and its a pretty car!
Old Jul 22, 2005 | 09:14 AM
TheCheeseWedge's Avatar
i was running 92 civic front knuckles for a few months on my 88 crx.while i was building up my ef knuckles with extended wheel studs and new bearings. you have to get an alignment though when using eg knuckles because it is a big difference in the toe. i have type r gab sport shocks on the rear with im thinking to be an integra compensating arms. i had to lower it to the lowest setting just to get my camber to zero in the rear otherswise it was positive
Old Jul 22, 2005 | 10:19 AM
rice_classic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wu tang &raquo;</TD></TR><TR><TD CLASS="quote">heres another pic
Wow... Just...Wow!
