Painted my car
Old Jul 11, 2005 | 08:05 PM
BiG Chris's Avatar
Default Painted my car
Well my car had problems with the clear chipping and peeling really bad on the hood and other places so i finally got tired of it and this is what i did...
Started with this notice the peeling on the hood...
Here we go...
Sanding
Masking
Primer
Paint
back together
now wet sanding rubbing compound and polishing one side
result
and the result for one side
Now its nothing near perfect but i did it all myself and ive never painted a car so this was my first time. Next time i know what to do differntly for better results.... so if you think it looks like crap ohh well.....
Old Jul 11, 2005 | 08:10 PM
shawn_crx's Avatar
Default Re: Painted my car (BiG Chris)
really nice... where is the clear/top coat?
Old Jul 11, 2005 | 08:23 PM
insomniac791's Avatar
I think you should either get the full body kit or put your stock front bumper back on.
The paint looks really good though
Matt
Old Jul 11, 2005 | 08:31 PM
Andy R's Avatar
Default Re: (insomniac791)
agreed, I think you did a great job, but I'd stick with the stock bumper. With as straight as your body is, a clean stock bodied crx is hard to come by these days.
hehe, looks like overspray owned you Y49
Old Jul 11, 2005 | 08:32 PM
tilt's Avatar
nice diy job. can you elaborate on the equipment used? like what kind of paint, paint gun, air compressor size? thanks.
Losrocket_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by insomniac791 &raquo;</TD></TR><TR><TD CLASS="quote">I think you should either get the full body kit or put your stock front bumper back on.
Matt</TD></TR></TABLE>
I agree. Either run the full kit or keep the stock front bumper. It looks very unproportional with just the front bumper. Nice DIY paint job though
Old Jul 11, 2005 | 08:34 PM
ukdm crx's Avatar
Yeah putting just the front bumper on looks fucknig dumb get the rest of the kit or upgrade to 90-91 front end.
Old Jul 11, 2005 | 08:36 PM
fkguitar's Avatar
Default Re: (Andy R)
Wow that paint looks good. Could I get some details? I mean you said this was your first time painting a car so I gotta ask did you use like a pro setup minus the booth to paint it with?
Old Jul 11, 2005 | 08:43 PM
EF9Si-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by insomniac791 &raquo;</TD></TR><TR><TD CLASS="quote">I think you should either get the full body kit or put your stock front bumper back on. </TD></TR></TABLE> I disagree!
Maybe if you painted the bottom half of the Bumper black sort of like the stock bumper, the two tone color scheme, it will look better. I saw one some where on here. but I dont recall whos it was. He did silver and lower part black. I thought it looked good. Plus you can save ur self some money and avoid having to buy the rest of the kit or the stock bumper and put in the work to get it yellow. I like how it looks nonetheless but not full yellow bumper. GOOD job on the paint.
Old Jul 11, 2005 | 08:52 PM
Andy R's Avatar
Default Re: (fkguitar)
I'm not sure on his specifics, but its pretty easy. I have a automotive specialized paint store that sells all Dupont products. Prices on base coat depend on the portions, but typically it is going to run you around $60-100 for 2 pints of base. Then add on about $30 for a pint of etching primer, and $70 for enough base and primer activator. A large gallon of clear and activator will run about $100, but will last for multiple jobs. So your looking at close to $300 for all the primer/base/clear and appropriate activators. Recommend using a gravity feed air paint gun, as you will save on lost paint, and easier to keep from sucking air when gun is tipped. The $60 guns will work fine, i've had good results and not much difference between using a $60-90 gun compared to a $300 gun. Good results overall are a product of the preparation. If you don't sand down into the old base and don't clean any oils off, you'll get bad results. For a compressor, having a motor that runs 9+ cfm is preferred, but you can get away with less if you let the motor catch up periodically. Make sure you where masks and have some sort of ventilation, have known people you passed out after painting for an hour+ without a mask in a non-vented environment. Your lungs will thank you!
Old Jul 11, 2005 | 10:05 PM
BiG Chris's Avatar
Well the paint i used was from ppg it ran about 130bux its a one step which means the clear is in the paint already and i purchased a quart. i used a hvlp gun wich is a high volume low pressure gun which works good and one cost about 75 bux ive had the compressor and its a 30gal no problems there. im not going for show quality paint yet as it was my first time and i wanted my car all tha same shade of yellow. also the rest of the kit is coming but i might put the oem bumper back on.
Old Jul 11, 2005 | 10:06 PM
RangerDan's Avatar
Some overspray, but it looks great. Ive always wanted to paint a project car fear I would always royaly screw it up!
Old Jul 11, 2005 | 10:57 PM
BiG Chris's Avatar
thats why i used cheap one step paint next time i will go 2 step process
Old Jul 11, 2005 | 11:18 PM
FlatBrokeHatch's Avatar
Default Re: (BiG Chris)
Nice diy man. You should def go back to the stock bumpercover.
Old Jul 11, 2005 | 11:46 PM
jdmnivek's Avatar
nice job
clean ass rex's Avatar
Default Re: Painted my car (shawn_crx)
I like the color, but a oem bumper would look better.
Old Jul 11, 2005 | 11:54 PM
jdmnivek's Avatar
Default Re: Painted my car (clean *** rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean *** rex &raquo;</TD></TR><TR><TD CLASS="quote">I like the color, but a oem bumper would look better. </TD></TR></TABLE>
i totally agree.
Old Jul 12, 2005 | 02:42 AM
94_HATCH's Avatar
Default Re: Painted my car (jdmnivek)
Doesnt look bad at all for a first time painter. Did you paint your antenna yellow on purpose
Old Jul 12, 2005 | 05:59 AM
JIDUM_Undercover's Avatar
hmm, not bad for a DIY paint job probably woulda lost the ww front though oem is so much cleaner.
Old Jul 12, 2005 | 06:06 AM
CBURKE's Avatar
Looks really good, but in all the taping you never thought about covering the wheels?
Old Jul 12, 2005 | 06:23 AM
Rob.'s Avatar
That front bumper + headlights are so nasty !
Old Jul 12, 2005 | 07:18 AM
CRX Toad's Avatar
Good job dude....props to you
Old Jul 12, 2005 | 07:54 AM
Newark Built's Avatar
* B A N N E D *
Default Re: Painted my car (CRX Toad)
Good job for first timer
BUT!...
If i was you I wouldve atleast removed the lisence plate, taillights, removed the sunroof (so you wouldnt have to paint the weather stripping)...
In painting its all about prep.
Old Jul 12, 2005 | 08:29 AM
FOMULA91's Avatar
Default Re: Painted my car (Newark Built Kandy SiC-RX)
I like it when it was white but the yellow make it better.
Old Jul 12, 2005 | 08:38 AM
Its me DUB's Avatar
Default Re: (CBURKE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE &raquo;</TD></TR><TR><TD CLASS="quote">Looks really good, but in all the taping you never thought about covering the wheels?</TD></TR></TABLE> Looks like he used garbage bags...I don't think that's a bad idea.
