Suspension & Brakes Theory, alignment, spring rates....
Problem with comptech swaybar
Old Jul 11, 2005 | 07:32 PM
tegmaniac's Avatar
Default Problem with comptech swaybar
I installed a comptech tie/swaybar combo in feb. for my integra and since then, the bar is slowly moving more and more to the left, so now it is atleast 2 inches off center. Those collars they use to keep it centered are now loose, which is why it keeps moving . Is there anyone else out there with the same problem and if so, what was your fix? Thanks for any tips.
Old Jul 12, 2005 | 04:38 AM
AutoXer's Avatar
Default Re: Problem with comptech swaybar (tegmaniac)
I've had mine on for about a year. This weekend I was pullling it apart to lube the bushings, and my collets had broken loose as well; although mine stays pretty much centered. I'm guessing the only 'fix' would be to get some sort of collar from the hardware store that you can fix with a set screw or something, but I'm not sure how much better that would be.
Old Jul 12, 2005 | 02:44 PM
808_si's Avatar
interesting, I'm in the market for a sway bar setup. let us know how you fix it! thanks.
ekpoop.
Sep 25, 2005 04:06 AM
gakkuken
16
Dec 22, 2003 02:10 PM
montyww
Sep 5, 2003 12:40 PM
GSR-REX
Oct 8, 2002 05:00 AM
EKhatch
10
Jul 26, 2002 06:25 AM
