camber kit dilema!!
i have a 98 hatch, converted the rear drum brakes to disc brakes by taking an entire acura rear suspention...now i'm planning to lower it but they make two models for camber kit one for integra and civic....now which one u guys think will work! need u'r 2cents on this one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mperezkr »</TD></TR><TR><TD CLASS="quote">CIVIC</TD></TR></TABLE>
If you're talking about a camber kit for the rear, dont waste your money on it. I don't think I've ever heard of one for the rear anyway. Just put a washer, or more depending on how much you lower it, behind each of the 2 bolts on the mounts for the rear upper control arms and it will be close enough, and it only costs as much as the washers.
And if its for the front then:<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mperezkr »</TD></TR><TR><TD CLASS="quote">CIVIC</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importrcr »</TD></TR><TR><TD CLASS="quote">http://home.earthlink.net/~civ....html
Try that it should have what you need.</TD></TR></TABLE>
Thats it right there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboCoop »</TD></TR><TR><TD CLASS="quote">If you're talking about a camber kit for the rear, dont waste your money on it. I don't think I've ever heard of one for the rear anyway. </TD></TR></TABLE>
OMNI, Ingalls, etc...make rear camber kits. They replace the arm the you put the washers behind and are adjustable so you can dial in your desired camber without having to worry about 2 or 3 washers tying to act as a static connection..
Player_One
Suspension & Brakes
Jun 6, 2007 10:03 AM
4drEF
Aug 13, 2004 08:23 PM
Mugen Hamster
19
Apr 30, 2003 03:02 PM
