zc chugging???
dohc zc chuggs at 2k to 3k lil chuggs like its not getting enough fuel.im throwing tps code could this be the reason?i changes my fuel fitler,cleaned injetors really good,blow the fuel line out with an air line.still chuggs.any ideal what what this could be?
im having the same problems. mine just started when i switched back to my stock head.
also does yours hesitate if you hit the throttle quickly from idle. kind of drops off then revs when you hit the gas.
anything i find out i will pass down to you. also if you find anything let me know. i would appreciate it.
no doesnt struggle from idle to wot and gets up and goes,this only happens at low throttle,now i was thinking if i got safc would this fix the prob. becuase then i could adjust the hi low throttle?i dont know im just throwing up some ideals on how to fix it,and yes it could be tps sensor but it was throing the code long before it started doing this.or could the tps sensor just went completly bad to were it runs shitty?maybe before it was ok just not adjusted and now its not working at all?let me know what yall think bout this.
ghettoda9
Mar 1, 2012 04:27 PM
drewboy
May 12, 2005 02:58 PM
