little info re: trailing arms 92 on a 98 civic coupe
Old Jul 11, 2005 | 05:37 PM
technine's Avatar
Default little info re: trailing arms 92 on a 98 civic coupe
Just finished up replacing the passenger side trailing arm (rear knee pick n pull calls it) and found out some really interesting info (pain in the a$$). Long story short, I took a trailing arm assymboly off a 92-95 civic 4 door and put it on a 98 civic 2 door ex. The older trailing arm is identicle, BUT the rear brakes are smaller (drum brakes) than the 98's.
What I ended up doing was replace the brakes with the 98 brake drum and change the spindle and hub because the 92-95 spindle was a different bolt pattern than the 98 drum brakes. Made a 15min job take a lot longer than 15min.
Hope that helps someone here.
Old Jul 11, 2005 | 07:08 PM
sohcvtec1995's Avatar
Default Re: little info re: trailing arms 92 on a 98 civic coupe (technine)
rear drums on dx and lx are smaller thatn on ex's. Thats old news.
Old Jul 12, 2005 | 12:49 PM
technine's Avatar
Default Re: little info re: trailing arms 92 on a 98 civic coupe (sohcvtec1995)
Now I know... thought it was just a generation issue. I still didn't know the spindles were different.
Old Jul 12, 2005 | 01:04 PM
xEnderx's Avatar
So did you have the pleasure of trying to get that locktite crap off the bolts? I remember the first brake conversion I did....didn't know about the locktite. I actually broke it loose by hand. Ouch!!!!
Old Jul 19, 2005 | 04:07 PM
technine's Avatar
Default Re: little info re: trailing arms 92 on a 98 civic coupe (xEnderx)
All bolts came off smoothly, didn't know they had any loctite on them. I'm glad they did because I was pretty pissed already buying the torque bits to take off the spindle.
macias98Ex
Aug 5, 2011 09:55 PM
ShreqBoi
Mar 16, 2010 06:08 PM
sk8board{Pete}
Oct 22, 2008 09:17 AM
gulftiresinc
Sep 27, 2007 11:32 AM
