B16A2 + Custom Turbo Kit COMPLETE EVERYTHING 265whp DYNO PROVEN! 5500
LOCATED IN BAY AREA BUT WILL DELIVER for 50$
This is coming out of a 93 civic ex coupe so if you have the same car this will fit exactly!!
Motor has about 45k miles on it and 4k boosted miles
Tranny has 4k miles on rebuild
Custom Turbo kit is 100% brand new parts and only 4k miles of use
Valve adjustment done with turbo install
Compression is checked and perfect.
Engine Mounts
Shift Linkage
Polyurethane inserts for mounts and shift linkage
Chrome chipped p28 ecu ready to go
Walbro 255 hp fuel pump
Precision saturated 440cc injectors
2000 B16a2 full swap alternator etc, with legit papers.
70mm STR throttle body
70mm port matched(to tb) aebs intake manifold
Hondata intake manifold gasket
Spooling Performance 2.25in intercooler piping
Clamps/couplers
Johnny Race car 7in 400hp black painted intercooler
Tial 38mm wastegate with 7lb spring chrome
Tial bov 50mm chrome
Precision SC50 t3/t4 turbocharger NO SHAFT PLAY
Oil drain and steel braided feed from fast-turbo
Blox Lifetime warranty cast iron turbo manifold
Spooling Performance dump tube
Spooling performance 2.5in down pipe w/ y-pipe
DHM Lifetime warranty 2.5in e-cutout
Golden Eagle Cam Gears
B16a2 Transmition
Redzone stage 3 clutch 500hp +
Act Streetlight 12lb flywheel
LS 5th gear
Boost gauge
Vacuum lines
Motor is tuned on 5 to 6 psi stock wastegate never pushed to hard, and good comp, everything is all taped and fited inside of the car you will get everything
we are going to be a D16 Stock Motor in the car, 2 many state ref tickets and he has to pay it off.
Car made 255whp/176 torque with the 2.25in exhaust and 265whp with cutout open + some torque
Redzone Tuned runs great.
GARENTEED START UP!!!
Call or E-mail Drew
Aim = Drewscanizer
(510) 258-1381
pics in car
Asking 5500 For EVERYTHING COMPLETE! You will need nothing your getting the full setup, ecu already tuned and everything.
Modified by Quad-Damage at 7:56 PM 7/5/2005
Modified by Quad-Damage at 7:57 PM 7/5/2005
Modified by Quad-Damage at 6:29 PM 7/11/2005
Engine Mounts
Shift Linkage
Clamps/couplers
B16a2 Transmition
LS 5th gear
Boost gauge
Vacuum lines
Call or E-mail Drew
Aim = Drewscanizer
(510) 258-1381
pics in car
crispchris
Northern California (Sales)
13
Jul 18, 2009 12:06 PM
Rob!
Northeast (Sales)
22
Sep 5, 2007 07:37 PM
Quad-Damag
21
Jul 13, 2005 06:21 AM
Huee
May 19, 2005 08:43 PM
