88 crx with zc swap problems
Old Jul 11, 2005 | 05:20 PM
pdorow's Avatar
Default 88 crx with zc swap problems
my buddy swapped a 1988 zc into his 88 crx si and we have spark and fuel and timing is right but i think that you need a 89 si ecu and he says that the 88 should be ok? please help
Old Jul 11, 2005 | 05:40 PM
tcmotorsports's Avatar
Default Re: 88 crx with zc swap problems (pdorow)
what is the problem? If it is not starting...check all your grounds, make sure that you check for spark and fuel.
Old Jul 11, 2005 | 05:56 PM
pdorow's Avatar
bump
Old Jul 11, 2005 | 06:02 PM
crxmrder's Avatar
does it turn over? does it just click? have you checked the dizzy, ignitor, coils or any of the pic ups in the dizzy itself?
make sure to check the thermostat ground. that it the main ground for the ecu as well
Old Jul 12, 2005 | 04:33 AM
bigfuhrm's Avatar
Default Re: (crxmrder)
definitly check the thermostat ground. also turn key to run position but dont start. you should see the check engine light come on. when you see it go off it should clik which is the main relay.
if it doesnt click its a ground problem. then you can just take a wire from the thermosta ground disconnected from the housing and run it to the battery and see if that solves your problem.
if so just find a new place to put the ground.
Old Jul 12, 2005 | 06:10 AM
civais's Avatar
Default Re: (bigfuhrm)
Who did the distributer wiring..are you 100% that it is correct?
Old Jul 12, 2005 | 09:21 AM
pdorow's Avatar
is the 88 si ecu alright though
Old Jul 13, 2005 | 02:23 PM
pdorow's Avatar
bump
Old Jul 13, 2005 | 02:32 PM
ghonaherpalitis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdorow &raquo;</TD></TR><TR><TD CLASS="quote">is the 88 si ecu alright though</TD></TR></TABLE>
yes
double check your pinouts
dturn89
Jun 1, 2010 08:35 AM
kojack_0
Nov 24, 2008 03:05 PM
Phils
55
Jun 29, 2007 06:40 AM
cticknor666
13
Sep 27, 2006 10:34 AM
h22_crx
Apr 4, 2006 04:48 AM
