ef sedan won't start, CEL no code good ecu b16a swap
Old Jul 11, 2005 | 01:41 PM
aaronhume's Avatar
Default ef sedan won't start, CEL no code good ecu b16a swap
okay so I was driving along after installing a fuel pressure regulator, and hard wired my radiator fan to a black/yellow wire that was a smaller one than the 8 guage or whatever the big ones are. I had been able to drive it around the block, but when I took it out over 5k rpms it just shut off... I tried the ecu in my crx and it works fine, the crx one does not work in this car either. I also tried a different main relay and that made no difference. I unsoldered the fan wire to be safe. I am quite sure that the problem lies in wiring or maybe another relay that I should check... not sure. I also checked all the fuses and they look fine.
Old Jul 11, 2005 | 04:49 PM
aaronhume's Avatar
Default Re: ef sedan won't start, CEL no code good ecu b16a swap (aaronhume)
bump...
Old Jul 11, 2005 | 04:59 PM
Redline130's Avatar
Have you checked for spark and/or fuel? What condition are your plugs, wires, cap and rotor? All your grounds nice and secure?
Old Jul 11, 2005 | 05:12 PM
aaronhume's Avatar
Default Re: ef sedan won't start, CEL no code good ecu b16a swap (Redline130)
okay the car has been running perfectly up til this point. grounds and stuff are definately good. no fuel pressure, according to my guage, which showed pressure before. basically something is not turning on to prime the fuel rail. I highly doubt the pump would go out, and even if it did would the check engine light come on? what other circuits would make it do that witthought leaving a code?
Old Jul 11, 2005 | 11:17 PM
aaronhume's Avatar
bump... I'm selling my crx and need the civic to work very soon
Old Jul 11, 2005 | 11:23 PM
NikoZai's Avatar
Does the car have power? 12v+ at battery? tell us something man.
Check the manual and go through all the troubleshooting steps
http://www.norcalcrx.org/library/
Manual is there.
Old Jul 12, 2005 | 08:06 AM
aaronhume's Avatar
Default Re: ef sedan won't start, CEL no code good ecu b16a swap (NikoZai)
yep 12V+ at the battery... engine cranks but no fuel
Old Jul 12, 2005 | 08:38 AM
JDMcrxb16a's Avatar
Check to see if all the injectors are plugged in. Check all fuel return lines.
Old Jul 12, 2005 | 09:56 AM
Redline130's Avatar
What fuel pump are you running?
Old Jul 12, 2005 | 05:06 PM
aaronhume's Avatar
factory one. no difference in fuel useage, as regulator is set at 38 psi. the positive 12v that is switched on by something is not coming on when it should. that is why the fuel is not priming. I have no idea what the problem is.
Old Jul 12, 2005 | 06:12 PM
dr_latino999's Avatar
It couldn't hurt to pick up a new fuel pump, the Walbro 190s (there in that area) aren't that expensive.
Old Jul 12, 2005 | 07:02 PM
aaronhume's Avatar
Default Re: ef sedan won't start, CEL no code good ecu b16a swap (dr_latino999)
ok like I said its not the fuel pump. if the pump recieved a signal it would turn on.
Old Jul 12, 2005 | 09:05 PM
Redline130's Avatar
Have you traced the wiring from the pump to the main relay?
Old Jul 13, 2005 | 11:15 AM
aaronhume's Avatar
okay problem solved today... I re-checked the #14 fuze today and it was dead so I put a new one in and boom it starts! my bad... lol i went for 14 days without it because of a freakin fuse
rudyndrew
21
Jun 23, 2011 09:00 PM
justin1785
Mar 18, 2011 06:08 AM
frizzle
Jan 23, 2010 09:35 PM
ChilBlu92
14
Jul 30, 2009 08:30 PM
Fezzie
Mar 25, 2007 05:29 PM
