VSS WIRING / ITR Cluster swap into 89 CRX
quick question. in order to wire up my electric VSS I need to tap and split into the signal wire going to the ECU. I was told that the wire is present at the CRX cluster plug. I need to confirm if its pin D5 on the smaller CRX cluster plug. Its marked unused on all the CRX diagrams and the color is yellow with a red stripe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kylefakesi-r »</TD></TR><TR><TD CLASS="quote">signal is yel w/ red stripe. it is located on connector c710 pin #7.</TD></TR></TABLE>
Are you refering to the larger 12 pin connector? if so thats for oil pressure
the small connecter has a yellow and red too marked unused its D5
http://www.ef-honda.com/ben/DCcluster.php
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kylefakesi-r »</TD></TR><TR><TD CLASS="quote">check your pm...i just sent you some info that should help alot</TD></TR></TABLE>
