grounding your car
so do you guys think that grounding your car better with thicker wire will help your car out a lot...and would you all kno the 8 grounding points in an ek?
https://honda-tech.com/zerothread?id=1237582
This has a few links that should help out somewhat.
-Shane
-Shane
No problem. Help you out a little bit? I know some of the spots to ground, but not all of them. If you search, there were many other threads that pertain to grounding if you would like. Just search for "grounding" archived and you should be good to go.
-Shane
-Shane
y0_calvinn
Northwest
Sep 20, 2011 07:58 PM
