Valves tapping?
Old Jul 11, 2005 | 10:01 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Valves tapping?
I think valves tapping. When I gas it in 5th, I can hear tapping sounds fro the engine. Is that valves? Will a valve adjustment solve the problem?
TIA
Old Jul 11, 2005 | 10:05 AM
Luserkid's Avatar
Default Re: Valves tapping? (GoLowDrew)
Thats really vague.
when you need a valve adjustment you hear the valves in every gear and idle. Can you describe the sound better? What rpm does it happen?
Deemeetree's Avatar
Electrician
You never know if it will solve the problem, but it wouldn't hurt. Maybe injectors?
Adjust the valves and go from there.
Old Jul 11, 2005 | 10:12 AM
postman's Avatar
Default Re: (Deemeetree)
the injectors can click fairly loud sometimes
Old Jul 12, 2005 | 01:04 PM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Re: Valves tapping? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Thats really vague.
when you need a valve adjustment you hear the valves in every gear and idle. Can you describe the sound better? What rpm does it happen? </TD></TR></TABLE>
On the hwy at about 70-80mph 5th gear at about 3,300 rpm. step on the gas a bit, to pass some one (still in same gear), and I hear the tapping sound. Let go the gas to cruise @ 70mph, and the sound stop.
Old Jul 12, 2005 | 01:08 PM
xEnderx's Avatar
You are positive its not a rod knocking? Does it do it at higher RPM in any other gear?
Old Jul 12, 2005 | 01:22 PM
kkim's Avatar
Default Re: Valves tapping? (xEnderx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xEnderx &raquo;</TD></TR><TR><TD CLASS="quote">You are positive its not a rod knocking? Does it do it at higher RPM in any other gear?</TD></TR></TABLE>
...or pinging. what does the tapping sound like? a consistent, rhythmic tapping or more like a bunch of marbles in a muffled can being shaken up?
Old Jul 14, 2005 | 10:22 AM
GoLowDrew's Avatar
Old Member
25 Year Member
In lower gear, I can't tell because of my exhaust. But I don't think so. So it's higher RPM where it's perhaps closer to 4K in 5th gear where I hear the sound.
As for pinning? Yes. It does sound like marbles in a can. I run on 87. But on that trip, I had fuel injection cleaners in the tank. Did that make a difference?
TIA
Old Jul 14, 2005 | 10:24 AM
kkim's Avatar
check your ignition timing.
Old Jul 14, 2005 | 10:30 AM
D16Z6_turbo's Avatar
what motor is this? if it's a vtec motor then it could be your LMA's that are going bad.
Old Jul 14, 2005 | 10:36 AM
JDM-EJ1's Avatar
To stress on more what Luser was saying..
When I'm idleing at a stoplight, I can hear a *tick tick tick* noise, and also when I'm normally driving. A valve adjustment would help lessen this, but the noise will still be there. My brother got one on his DA9 a month or so ago, the ticking is still there, it's not as loud though.
lsvteg11
11
May 3, 2014 12:44 AM
Cadyfatcat
Aug 2, 2012 01:56 AM
dcsports
20
Nov 11, 2005 10:15 PM
VTECcnIT
Nov 7, 2005 01:17 AM
wragen22
Apr 8, 2005 11:44 AM
