Water pouring out of floor vents
Old Jul 11, 2005 | 08:23 AM
Grayson's Avatar
Default Water pouring out of floor vents
I have a 97 Accord and it's hot down here in Tx. I've been running the AC for most of the season; and just recently when I take a hard corner I get decent amount water poring out of the floor AC vents.
There is nothing like giving your floor an ice cold bath on your commute to work to get you going for the day.
I'm guessing a drain is clogged somewhere right? Any ideas? Solutions?
Old Jul 11, 2005 | 08:30 AM
i20ar's Avatar
Default Re: Water pouring out of floor vents (Grayson)
https://honda-tech.com/zerothread?id=1301495
Some guy had the same problems i think they had the answer on this page
Old Jul 13, 2005 | 04:08 AM
FloydOnyx's Avatar
I also own a '97 Accord and have the exact same problem. I found that the drain plug on the bottom of the evaporator case was clogged. It is a simple problem to fix. Reach down under the case (directly under the glove box) and you will feel a rubber hose which extends from an attachment on the evaporator case and goes through the floor. Put a towel under this area before you pull this hose out, you may get quite a bit of water. Pull the hose out of the floor and off the case and clean it out. Also, you may have some detritus sitting in the bottom of the case itself and you may need to use a coat hanger to loop around from behind the outlet hole and try to loosen up this junk and let it flow out.
This is the easy part, it takes no more than 10 minutes. The bummer (at least in my case) is that the reason that the outlet on the evaporator case clogs up is that the styrofoam insulation inside the case is disintegrating and falling into the outlet. It is not an easy job to remove this evaporator case to fix this, so this (again, in my case) is a regular job for me. If you notice bits off styrofoam insulation comming out of your AC vents anywhere, then you probably have the same problem.
Hope this helps.
Old Jul 13, 2005 | 10:48 AM
drifter_for_life06's Avatar
happened to my 1997 LX and turnedout the problem was teh drain hose fr the A/C was clogged and over time everything behind my dash was colecting condensation and shorting out electrical circuits and dumpin into the floor almost every corner
Old Jul 16, 2005 | 12:35 AM
deserthonda's Avatar
proper and lasting way to fix it remove the evapor and clean it all up
Old Jul 16, 2005 | 03:14 AM
that was the only wy to fix my problem in the long run
thekid2390
Jun 30, 2013 12:15 PM
marrieda97accord
Jul 6, 2008 12:06 PM
nappyred
May 28, 2008 03:35 PM
r0nr0n
Oct 14, 2005 09:49 AM
Josh Carr
May 12, 2004 08:10 AM
