help oem stanley fog light install problem!!!!
ok i got a set of oem stanley fog lights for my eg and i spent all day playing with them. finally i found where all the clips plug in under the dash and wired everything up grounded the lights and everything and now there is no light. they wont turn on, does anyone have any help for me.
nah they wont turn on even with the head lights or parkin lights on. they came with a dash harness with 2 bypass plugs. a more dificult install than i figured.
Did you run the wire from the inside harness to the exterior harness? Check the fuse. Make sure the two plugs that go in the fusebox are the the right locations, 2 and 5.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazi92hb »</TD></TR><TR><TD CLASS="quote">but a burnt out bulb one would still turn on right</TD></TR></TABLE>
Not if both are burnt out
The USDM harness is different from my JDM harness. Did you plug in the plug that goes to your light switch as well as your dimmer switch? You have to ground the interior harness as well as the relay.
yeah i know i plugged in the harness to the light switch on the column and the dimmer switch grounded the relay under the dash and grounded the exterior harness to the chasis
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazi92hb »</TD></TR><TR><TD CLASS="quote">but there was no loose ground wire to ground on the interior harness.</TD></TR></TABLE>
There should be. That's the reason why it's not working. You need to have the harness grounded.
