golden eagle head studs???
Old Jul 10, 2005 | 09:33 PM
ali_232's Avatar
Default golden eagle head studs???
i am building my lsvtec right now and i was thinking of getting a golden eagle head stud seat.
have anybody used them if so how are they???
Old Jul 11, 2005 | 12:01 AM
GOLDBERG's Avatar
Default Re: golden eagle head studs??? (ali_232)
i got some seem to be good quality
Old Dec 6, 2005 | 11:00 AM
itr_18's Avatar
Default Re: golden eagle head studs??? (GOLDBERG)
are Golden Eagle headstuds as good as ARP's?
Old Dec 6, 2005 | 11:09 PM
highendmike's Avatar
Multiple Accounts, banned multiple times
Default Re: golden eagle head studs??? (itr_18)
we use the golden eagle head stud's and they work fine. Highend autosports
Mike
Old Dec 7, 2005 | 10:19 AM
drdisco69's Avatar
Golden Eagle Great customer support too.
Old Dec 7, 2005 | 02:51 PM
Rocket's Avatar
Default Re: golden eagle head studs??? (drdisco69)
Curious. How many of you guys are bottoming out the studs?
Old Dec 7, 2005 | 02:57 PM
projectTeG's Avatar
also interested
Old Dec 7, 2005 | 03:36 PM
drdisco69's Avatar
Default Re: golden eagle head studs??? (Rocket)
I am, to the 7 lb*ft they specify. It's sort of the reason I got the GE ones over ARP, the GE's have the "dog nose" to locate the stud.
Having said that, I know Rocket doesn't ask questions for the fun of it. What do you know that we don't?
Old Dec 7, 2005 | 03:44 PM
Rocket's Avatar
Just think about that a lil more sir.
Old Dec 7, 2005 | 03:49 PM
drdisco69's Avatar
I thought about it for quite a while before purchasing them. My ASSumption was that the holes drilled in the block for the head bolts are of a somewhat uniform depth, as it is Honda after all, not Ford... This would serve to locate all the threads equally in all the holes. Better than guessing...
Old Dec 7, 2005 | 03:53 PM
Rocket's Avatar
We used to use the AEBS studs bottomed out and we fucked up the threads in our block. We've since switch back to ARP not bottomed out and things are coo, even with "decent" power levels.
Old Dec 7, 2005 | 03:57 PM
drdisco69's Avatar
Well power certainly isn't a concern for me, it was a matter of reusability for about the same price as bolts. What problems with the threads did you have, pulling out? My thought was 7 lb*ft wasn't enough to cause trouble, especially since there's no more twisting those threads as you tighten.
Old Dec 7, 2005 | 04:01 PM
Rocket's Avatar
7lbs + more twisting (upon torquing) against the bottom. Something is gonna give right? Anybody crack a block yet?
Not trying to be hard on you Disco. Just being true to performance.
Old Dec 7, 2005 | 04:06 PM
drdisco69's Avatar
It's DOCTOR disco! I didn't spend 7 years in disco medical school to be called disco...
I can't recall the axial load of 7 lb*ft of torque on those bolts off the top of my head, but it doesn't strike me as something to crack the block. Also, I figured most of that force will be removed once the studs are tightened, due to the strain of the threads and studs.
No hard feelings at all, it's called learning.
Old Jan 7, 2006 | 10:13 AM
Golden Eagle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">7lbs + more twisting (upon torquing) against the bottom. Something is gonna give right? Anybody crack a block yet?
Not trying to be hard on you Disco. Just being true to performance. </TD></TR></TABLE>
nothing will give we make lots of power on these head studs no problems and no complaints from customers
Old Jan 7, 2006 | 12:28 PM
raffiT78's Avatar
yaa, go robert, tell him how it is woohoooo jk
Old Jan 7, 2006 | 02:12 PM
drdisco69's Avatar
Dude, this thread is sooo last year.
Old Jan 9, 2006 | 09:02 AM
Default Re: golden eagle head studs??? (Golden Eagle)
bump
Old May 25, 2006 | 11:24 PM
TH22EK9's Avatar
any new testimonies? i was eyeing arp's until i found ge hs.
i am wondering if anyone has had block distortion using arp's? this is a statement golden eagle makes:
"Golden Eagle head studs use the factory torque specs and sequence for much less block distrortion. ARP uses a torque spec that is WAY beyond the factory spec. We have used ARP many times and found them to distort the block and main tunnel significantly!"
buff1110
Nov 30, 2007 12:10 PM
harhoosh
Aug 28, 2006 12:10 PM
b20vtech
Feb 23, 2006 09:28 PM
b20vtech
Feb 21, 2006 07:23 PM
ShawnR
Dec 18, 2005 10:31 PM
