Brembo Blanks with OEM Replacement pads????
Old Jul 10, 2005 | 08:40 PM
97civicsedan's Avatar
B A N N E D
Default Brembo Blanks with OEM Replacement pads????
Are Brembo Blanks with OEM Replacement pads a good combo for a ek. Or should i get a different pad like hawk? Has anyone tried this combo?
Old Jul 10, 2005 | 08:44 PM
EMJAY's Avatar
if you changing blanks why not change pads too? i'm running powerslots with hawk pads its a pretty good setup
Old Jul 10, 2005 | 08:49 PM
Deemeetree's Avatar
Electrician
Most people who I've seen running Blanks also ran with Hawk pads. Might as well upgrade...
Old Jul 10, 2005 | 09:03 PM
B A N N E D
Default Re: (Deemeetree)
OK I will upgrade Thanks. Also who has hawk pads cheap??
Old Jul 10, 2005 | 09:26 PM
EK k kay's Avatar
Default Re: (97civicsedan)
Try H-T sponsor ImportRP or http://www.importrp.com.
If you're only looking to replace worn out pads for daily driving then OEM will be fine. They also are low on brake dust.
Old Aug 3, 2005 | 10:49 AM
8200RPM's Avatar
local hippie
Default Re: (wadup)
^^ sweet... im doing some research on cross drilled/slotted vs blanks also... helpful link btw
Old Aug 3, 2005 | 10:51 AM
AntMan401's Avatar
I have Axiss Metal Brake Pads and they are awesome.
Just running OEM Pads in the Rear and will be upgrading to Brembo Rotors later on.
Old Aug 3, 2005 | 11:01 AM
8200RPM's Avatar
local hippie
Default Re: (JDM:_hotness)
cool, I wanted cross drilled/slotted rotors but I searched on here and most people say brembo blanks are probably best for a couple reasons. so ill probably get that and oem pads.
Old Aug 3, 2005 | 11:38 AM
timisyourfriend's Avatar
Default Re: Brembo Blanks with OEM Replacement pads???? (97civicsedan)
Brembo blanks with AEM brake pads. hands down the best. trust me, you'll think you have 11" rotors with 4 piston calipers. haha
Old Aug 3, 2005 | 11:59 AM
alotawatts's Avatar
I'm having good luck with blanks and Nissin pads
Modified by alotawatts at 3:38 PM 8/5/2005
Modified by alotawatts at 3:55 PM 8/5/2005
Old Aug 3, 2005 | 12:07 PM
The Internet Tough Guy's Avatar
Default Re: Brembo Blanks with OEM Replacement pads???? (alotawatts)
autozone rotors are just as good as brembo blanks and they're cheap. it makes no sense to spend money on a wear item.
and cobalt gt sport pads own
Old Aug 3, 2005 | 12:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alotawatts &raquo;</TD></TR><TR><TD CLASS="quote">I'm having good luck with blanks Nissan pads</TD></TR></TABLE>
Nissin pads you mean? Which are AEM pads...
Old Aug 5, 2005 | 02:39 PM
alotawatts's Avatar
Default Re: Brembo Blanks with OEM Replacement pads???? (JZPerformance)
....typo...meant to say and Nissin pads. I'd bet AEM are made by Nissin !
Yup !
Found this:
AEM High Performance Brake Pads are specifically engineered for high-performance braking. These pads are manufactured in conjunction with O.E. Japanese brake manufacturer Nissin, and utilize a unique ceramic-Kevlar fiber compound to provide a higher coefficient of friction that resists fading and reduces stopping distances.
Modified by alotawatts at 3:56 PM 8/5/2005
Old Aug 5, 2005 | 06:59 PM
kkim's Avatar
Default Re: Brembo Blanks with OEM Replacement pads???? (The Internet Tough Guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Internet Tough Guy &raquo;</TD></TR><TR><TD CLASS="quote">autozone rotors are just as good as brembo blanks and they're cheap. it makes no sense to spend money on a wear item.
Yes, I agree. Spend the money on a good pad instead of the rotor. I use the cheapest rotor I can find at the local autoparts store (rotors are heavy to ship) plus I like PBR/Axxis Ultimate pads. Adjust your rear drums, if you have them, and you'll have excellent brakes for very little money. Also, flush system w/ a decent brake fluid... Valvoline syn power... cheap and effective.
Old Aug 5, 2005 | 08:03 PM
Sijray21's Avatar
Autozone rotors with Axxis Ultimate Pads
Best Value and GREAT stopping for the street
Old Aug 5, 2005 | 09:57 PM
mike93eh
Guest
Posts: n/a
best cheap setup = brembo blanks, axxis pads, goodridge ss brake lines.
Old Aug 5, 2005 | 10:01 PM
EK 2.0's Avatar
Default Re: (mike93eh)
my set-up is Blanks with HAWK HP+ and I love the set-up...its the same I was running on my DSM...and never ever failed me
bmoua
14
Dec 6, 2006 09:46 AM
AFAccord
Oct 15, 2005 12:52 PM
boostincoupe
22
Jul 31, 2005 03:22 PM
