84mm gsr combustion chamber volume question for the masters
Old Jul 10, 2005 | 07:16 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default 84mm gsr combustion chamber volume question for the masters
I opened up my p72 combustion chambers to 84mm and also deshrouded. I cc'd the chambers to 44cc's each. Stock is around 41.60cc each according to the C-Speed compression calculator. I want to get the head milled to return the volume close to or right back at 41.60 or so. How do i figure out the amount of milling to achieve this? Thanks techies.
Old Jul 10, 2005 | 07:32 PM
Yambor's Avatar
Default Re: 84mm gsr combustion chamber volume question for the masters (not so civic)
well u get a 9.58:1 CR with stock internals and stock hg and no milling with your 44cc volume..
Im using stock just for an example here..
so..stock cr is 10:1
so start by taking off hg thickness on the calculator...
You want to get that cr back up to around stock:
so stock is .029, take .005" off, gets you to 9.69:1
" " take off .010" nets you 9.8:1
" " take off .015" net you 9.9:1
" " take off .020 net you 10:1
there ya go...this gets you back to near stock volume..
you can do this buy using a 2layer hg. of .4mm which is .015748 - .029000 stock thickness = .013252 then mill .006"..
Cheers
Old Jul 10, 2005 | 08:16 PM
Yambor's Avatar
but since you are trying to reduce the physical volume, not buy using a smaller hg , you would need to mill all .020.. which i wouldnt recommend if you are using high lift cams and big dome pistons
Old Jul 10, 2005 | 08:40 PM
Default Re: (JH4DC4-2GSR)
Skunk stage 2, and Wiseco 11.8:1's. Before I touched the chambers I ran a 1 layer w/ the cams and pistons. And it was 2 layer before I pulled the head again. I do want to be able to run a 3 layer stock gasket. Hey thanks for your time JH4DC4-2GSR.
Old Jul 10, 2005 | 09:05 PM
Yambor's Avatar
Default Re: (not so civic)
Sweet good deal man! hope that helped you out a little and gave u a general idea..
So hows that thing run? any slips etc? I would like a list of mods etc? To get more entusiasm into my gsr build
Old Jul 10, 2005 | 09:36 PM
oh it runs damn amazing especially with the 4.78-b16 gears. i haven't drag it at the track. i don't have a good drag wheel/slick combo for type r five lug/brakes. all we have is 1/8th mile local...my guess is deep 8's in the 1/8th, but i would like to spray it. i'll be taking pics of the portwork and heavily modified gsr intake manifold for documentation since i'll probably sell this hatch soon.
94lsboost
Apr 28, 2005 09:46 AM
crxjake
Jun 29, 2004 12:12 PM
blackitrspec
May 4, 2002 12:55 PM
