which clutch and throttle cable to use?
Old Feb 15, 2002 | 01:43 PM
BoostinDC2's Avatar
Default which clutch and throttle cable to use?
currently putting a B16 in a 91 crx. and just wanted to know which throttle and clutch cable to run
Old Feb 15, 2002 | 02:44 PM
wronghand's Avatar
Default Re: which clutch and throttle cable to use? (BoostinDC2)
What model CRX is it? If it is an Si or an HF you should be fine with your current throttle cable. If it is a DX you can use the DX throttle cable but it will be a little long.
Old Feb 15, 2002 | 02:58 PM
EL Vap133's Avatar
I used the 90-93 Integra cables in my DX.
Old Feb 15, 2002 | 03:49 PM
BoostinDC2's Avatar
Default Re: which clutch and throttle cable to use? (Vap133)
i have the si model. so i wont need to replace the throttle cable.
Old Feb 17, 2002 | 05:41 PM
13secondcivic's Avatar
New User
ok...not sure HOW these guys are using stock throttle cables, or for that matter clutch cables, but I just put a B16A1 into a 91 civic Si last week....LOL! You need a 91 integ throttle cable, 16 bucks, and clutch cable.
the throttle cable mount does not match up to the Si cable, and won't hold it in place. bracket is too far to the driver side. the integ cable looks and works like factory! the clutch cable is WAY too tight, and I'm having all sorts of clutch engagement trouble. doesn't leave any freeplay in the tranny arm or pedal. just buy the new clutch cable as well.....
madgeo
Jul 22, 2009 03:41 PM
4gencivicef9
Apr 9, 2006 07:18 PM
ironchef25
10
Jan 20, 2004 12:26 PM
sCeRaXn
Mar 3, 2003 05:46 PM
CRexcellence
Dec 11, 2002 03:12 AM
