o ringed ls vtec leakin oil from the headgasket
Old Jul 10, 2005 | 03:19 PM
5thgearburnout's Avatar
Default o ringed ls vtec leakin oil from the headgasket
I have a golden eagle sleeved b18b block with ther o ring option and when i change the headgasket i also changed the copper wire that is used as the o ring. it is know leaking oil from the headgasket above the oil filter. i used 18 gauge soft copper wire. i am wondering if the wire i used isnt soft enough. Any insight would be appreciated.
Old Jul 10, 2005 | 03:28 PM
SPOOLINmatt's Avatar
Default Re: o ringed ls vtec leakin oil from the headgasket (5thgearburnout)
those little things wont make the outer gasket leak. what about where they plugged the vtec hole in the head, have you checked head torque. is it leaking steady or is it staining the edge of the gasket.
Old Jul 10, 2005 | 10:38 PM
mattcivic's Avatar
Default Re: o ringed ls vtec leakin oil from the headgasket (SPOOLINmatt)
did u put the headgasket in uspide down??? someone on here just had a similar prob cuz there **** was on wrong take it out and see
Old Jul 10, 2005 | 10:48 PM
Redwidow's Avatar
The copper o ring shouldn't have nothing to do with oil leaking out side of the head/block. O ring is for a good Cylinder/Head Seal.. i like it..
eksleeper97
Engine Machining & Assembly
May 15, 2016 01:48 PM
93redeghatch
Oct 9, 2009 05:26 PM
ALL MOTOR DA
May 1, 2006 02:12 PM
ENeRg3Tic
Apr 30, 2004 06:43 AM
lsvtecvx
Dec 7, 2002 02:37 AM
