Oil coming from the breether on valve cover (turbo)
Old Jul 10, 2005 | 07:41 AM
Integra GSR 95's Avatar
Default Oil coming from the breether on valve cover (turbo)
He's my problems guys, I have a GSR with about 145k miles. Turbo pushing about 10.5 PSI. Didn't get around to getting a FMU but I have a turbosmart boost controller that wasn't regulating the boost at all. It was just like at 10.5 the waste gate was throwing it out. So yesturday I was driving it I got on it on the highway and got up to about 10, felt it running lean so I backed off, put it back up to about 7pounds and when I did it sounded like a gasket blew. No powwwwwwwww sound just a puffffffff of air I head kind of. I lookied under the hood and I have this oil that came from my breather on the strut bar and injectors. Whe I rev the car up sitting still alittle smoke comes from the breather along with oil. (not alot of oil just a bit)
My neighbor said it sounds like a valve spring gave out. When I take off I get no boost. The vaccum changes from vac to boost but boost still reads 0. So feed it to me straight guys, what did I blow?
Old Jul 10, 2005 | 07:48 AM
jagojon3's Avatar
Default Re: Oil coming from the breether on valve cover (Integra GSR 95)
Your ringlands.
Old Jul 10, 2005 | 07:50 AM
Default Re: Oil coming from the breether on valve cover (jagojon3)
is that my piston rings? Are the rings your talking about in the head? Where is that ****?
Old Jul 10, 2005 | 09:09 AM
dragsol's Avatar
You boosted with no fuel upgrades at all?
Old Jul 10, 2005 | 02:16 PM
Default Re: Oil coming from the breether on valve cover (dragsol)
Nope, No fuel mods at all.
Old Jul 10, 2005 | 02:32 PM
B16Civic93's Avatar
did you have any check valves in line with the map sensor or a missing link?
i dont see how the car even ran at all if you had no type of fuel upgrades no fmu, no afc, nothing at all to add more fuel per pound of boost. you thought you were running lean at 10psi? you were running lean at 1psi your car wont run right without any type of added fuel
to answer your question, it is most likely your ringlands, they are the things that your piston rings sit on.
Old Jul 10, 2005 | 03:35 PM
beepy's Avatar
Default Re: Oil coming from the breether on valve cover (B16Civic93)
Well, Darwin's law claims another Honda.
Old Jul 10, 2005 | 08:32 PM
ludelvr's Avatar
Default Re: Oil coming from the breether on valve cover (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Well, Darwin's law claims another Honda.</TD></TR></TABLE>
haha, yah, these numbers have been on a steady incline!!
But really, no mods to fuel at all! What the hell are you thinking!! I'd say your engine is pretty much toast. As for the ringlands, do a search, tons of info on them.
Old Jul 10, 2005 | 10:24 PM
vaporboy12's Avatar
Default Re: Oil coming from the breether on valve cover (ludelvr)
another one bites the dust
Old Jul 10, 2005 | 10:55 PM
RaNMaN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra GSR 95 &raquo;</TD></TR><TR><TD CLASS="quote">Nope, No fuel mods at all. </TD></TR></TABLE>
who told you to do that? beat them up.
Old Jul 10, 2005 | 10:58 PM
raceACCORDingly's Avatar
10 lbs with no fuel upgrades. genius!
Old Jul 10, 2005 | 11:03 PM
1995Ex_Sedan's Avatar
To the OP. When you add more boost. More power. More Hp to your car. You need the juice to fuel that extra oomph. You need bigger injectors. You need a management to tell your ECU to **** more fuel. You really, REALLY, should have done some homework before just going with stock injectors and no management.
I hope your story is a joke.
Old Jul 10, 2005 | 11:13 PM
Cloner's Avatar
Default Re: (1995Ex_Sedan)
Your motor is toast dude. Your pistons and rings are in the block.Think of it as a horse getting it legs chopped off.Dont believe The Fast and the Furious when he fried his rings and drove all over town.Doesnt work like that.
Old Jul 11, 2005 | 03:23 AM
lucidvtec's Avatar
at first my gsr was fine at the breather than like a week later a little bit of white smoke and a little oil started comin out...then out of nowwhere BOOM...#4 rings went out...time for a rebuild...now i can get some real power..i'm lookin foward to 400whp
Old Jul 11, 2005 | 05:34 AM
adseguy's Avatar
Default Re: (lucidvtec)
I get a chuckle when i see the post count and "what is this oil coming out of my breather for" Then we all say "dumbass" and they never come back in the thread . +1 for ringlands, man they have a ton of points lately
Old Jul 11, 2005 | 09:45 AM
turboH22Aakkord's Avatar
Default Re: (raceACCORDingly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceACCORDingly &raquo;</TD></TR><TR><TD CLASS="quote">10 lbs with no fuel upgrades. genius!</TD></TR></TABLE>
haha.. if it was only that easy...
Old Jul 11, 2005 | 10:00 AM
SOHC_MShue's Avatar
Are you a ******* stupid or something?
Old Jul 11, 2005 | 10:18 AM
90LSpimpin's Avatar
Default Re: Oil coming from the breether on valve cover (SOHC_MShue)
**** son, i get lil bit of oil comin out of my breather too. Ringlands eh? Meh, I'll just wait for it to blow and swap in another motor, it'll be cheaper lol.
Old Jul 11, 2005 | 10:21 AM
dc2legend's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">Are you a ******* stupid or something?</TD></TR></TABLE>
OH!&gt;!&gt;!
Old Jul 20, 2005 | 04:41 AM
To all of you, Just to let you know, that an intercooler pipe came off. It was causeing pressure to build up in the crack case causeing blowby. No damage done. I have oreder a complete fuel system up grade to make you people happy. haha. THanks for the input guys.
Old Jul 20, 2005 | 05:12 AM
Hyaboosta's Avatar
Default Re: (Integra GSR 95)
the ic pipe blowing off was causing no boost but there still should not be enough oil coming out of the breather to spill out of the filter. the rings are going.
Old Jul 20, 2005 | 05:45 AM
wantboost's Avatar
Who is Mr Robot?
I think you win H-T's offical Dumb **** of the year award
Old Jul 20, 2005 | 06:10 AM
nota-eg's Avatar
Lol, stupid is no longer an adjective, but a noun. HT is teh win! Horay!
for no FMU or fuel upgrades.
I'm running uber, WB, 310cc (only going to be about 7psi) and a 255lph inline.
I have a question for you uber/crome guys. Stock fuel pressure is 24psi. With an inline the pressure will be higher. Do I need to get a fuel pressure guage to find out what psi it's at so I know what to put into my .bin file?
Old Jul 20, 2005 | 07:58 AM
CRX T-Si's Avatar
Default Re: Oil coming from the breether on valve cover (nota-eg)
Damn...this is amazing I say........how in the world did it survived this long??
It's like Amazing...but really guys....lets not be too harsh....
Just last weekend, I meet some guy that just turbo charged his EG with a Greddy kit and I was checking it out right...so I asked him..so what kind of EMS are you using for the turbo.
The guy replied...none...everthing is stock SOHC..I was like doh!!!!! When ya tell someone something and they don't listen...what can you do right.
Soon...my other friend is gonna sell that guy another motor so its people like this that keeps other people in business.
Old Jul 20, 2005 | 08:14 AM
nota-eg's Avatar
Default Re: Oil coming from the breether on valve cover (CRX T-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">Soon...my other friend is gonna sell that guy another motor so its people like this that keeps other people in business.</TD></TR></TABLE>
You know, I thought of something like that yesterday. But instead it was aimed at ricers/JDMers.
If they wern't wasting their money on body parts to make their cars look cool they could be spending that money on go fast parts. The more they spend on looks, the less chance of them beating my car and the less chance of them killing an innocent person.
