lower left control arm
Old Jul 10, 2005 | 12:52 AM
kinkyintegra's Avatar
Default lower left control arm
im sorry if this has been asked before...i did a search all over the internet and did not find anything. well i just bought a 1989 integra ls for 300 dollars from a friend. he was driving and the control arm broke. now i took off the wheel and looked at it and noticed that the control arm is fine and at the end of it is a cup with a rubber thing. and then where it connects to behind the brake caliper there is a big metal ball. im guessing the ball used to be inside the cup on the end of the control arm and it popped out. so what i want to know is could i get that ball back in and keep driving the car or should i just go find a new control arm and install it. another question is how hard would it be to install a new arm...is it just nuts and bolts...i have knowledge on cars and i have friends who know alot but any help would be appreciated......thank you.
Old Jul 10, 2005 | 05:31 AM
Sam92Teg's Avatar
Default Re: lower left control arm (kinkyintegra)
Sounds like you need a new lower ball joint.
Old Jul 10, 2005 | 05:32 AM
Dogginator's Avatar
Daisy... Daisy...
Welcome to Honda-Tech.
It sounds like you split the ball joint. Check out this diagram:
http://www.acuraparts247.com/s...ch=no
Unfortunately, it looks like the lower arm and the balljoint are one piece.
Old Jul 10, 2005 | 08:09 AM
Default Re: lower left control arm (Dogginator)
so does that mean i need to purchase a new control arm or could i just replace the ball joint?
Old Jul 10, 2005 | 04:30 PM
do i buy a new lower control arm with ball joint or is it possible to replace the ball joint on the arm? please help its kind of urgent
Old Jul 10, 2005 | 04:56 PM
Dogginator's Avatar
Daisy... Daisy...
I'd guess that you need the entire arm. Call an auto parts to see if the stock just the balljoint.
Old Jul 10, 2005 | 09:41 PM
i just want to make sure i have the right part...heres a picture.... , im ordering this part..http://catalog.masterautoparts...mage= so is this the part i need??
Old Jul 11, 2005 | 08:13 PM
please can someone tell me if i am ordering the same part as the one i have taken out of the car?
Old Jul 12, 2005 | 03:27 AM
Dogginator's Avatar
Daisy... Daisy...
The description seems like the correct part.
wgbm92
May 24, 2012 08:28 PM
butter99
27
Nov 28, 2008 04:53 PM
M15
Apr 17, 2006 11:15 AM
94vtirozguy
Apr 14, 2006 11:37 PM
dpkelly
Oct 14, 2005 10:28 AM
