JL AudioStealth Box- Del Sol
Old Jul 10, 2005 | 12:35 AM
BlueDelSlow's Avatar
Default JL AudioStealth Box- Del Sol
hey I got a 94 Honda Del Sol and I got a custom box with 2 15's in the truck... Well Im going to be starting to travel a lot and I been reading up on this stealth box... I can only image it being a major downgrade to what im currently positioning... and yes I have dynamat... But how much of a downgrade? Can anyone help with suggestions I need trunk space....
http://www.cardomain.com/profile/delsolmarine
Old Jul 10, 2005 | 05:38 AM
nocturnaldragon's Avatar
Default Re: JL AudioStealth Box- Del Sol (BlueDelSlow)
This would get better responses in the audio forum.
But Ive seen the JL audio box and own two 10" subs currently there in the trunk in a bandbass which is hurting there performance. They should be in a box like the stealth one or something else. From my experiance those things are nice as hell (Subs) my 10" hit very nice + there what 8" top behind your seat? I dont think its a downgrade at all more of an upgrade. Also they have lower wattage then most speakers but they sound louder. Just a good product IMO, I have the matching amp to go with them as well. I also recomend getting a lower wattage amp then the speakers sp you never have to worry about blowing them out with a surge or an adjustment being off.
Old Jul 10, 2005 | 05:40 AM
1992HB's Avatar
I looked into getting it for my delsol but it is like $700-$800 for the JL stealth box. it has 2 JL 8" W1 which is equal to 1 JL 12" sub. I said screw that and did a custom setup with a kicker 200-2 amp bridged and 1 JL w1 10" sub in the trunk and alpine type s door speakers and rear speakers.
Old Jul 10, 2005 | 05:42 AM
Del Sol SiR's Avatar
well going from 15" to 8" is a huge downgrade. However, you can always replace those JL 8" with some higher end 8" woofers and get some really good bass.
Old Jul 10, 2005 | 05:46 AM
Default Re: JL AudioStealth Box- Del Sol (nocturnaldragon)
JL subs are better hitting then most for there size, and remember the stealth box helps them along with that. I agrea the box is wayyyyyyyyy overpriced, not to mention near impossible to find now from JL.
I should point out I know there are better subs then the JL BUT if he has low end ones now the JL will be an upgrade even if there smaller in size,
Its all a matter of opinion, I like tight hard hitting bass tho not the long whatever you call it you get from larger subs. Its just a matter of prefference I guess.
delsolo95
Oct 8, 2013 12:20 PM
teamaudiobox
14
Nov 5, 2011 05:11 PM
DeLsLo95Si
14
Jan 9, 2009 01:27 PM
DRKSol
Audio / Security / Video
Feb 28, 2007 10:56 AM
s2kds
Dec 18, 2003 06:47 PM
