ZC trannies? Anybody know how to identify them?
Old Jul 9, 2005 | 11:03 PM
trooper0641's Avatar
Default ZC trannies? Anybody know how to identify them?
Like for example which year, which car, gear ratio, stamps? What's compatible with what and so on.
Old Jul 10, 2005 | 03:52 AM
ServiceAdvisor's Avatar
The DOHCZC trannies usually have an intermediate shaft like the b-series. But not always, if I find the serial #s ill post 'em back here.
Old Jul 11, 2005 | 05:53 AM
jlicrx's Avatar
Default Re: ZC trannies? Anybody know how to identify them? (trooper0641)
ZC transmissions use larger diameter axles, so the splined openings where the axles go into the differential are larger - visually, everything else is the same as any other 88-91 L3 transmission - 88 has 21 splines, 89-91 has 20 splines, etc.
Old Jul 11, 2005 | 08:15 AM
HumanResource's Avatar
For the Gear ratios the spin and count is the most reliable way to find out
Old Jul 11, 2005 | 10:37 AM
Default Re: ZC trannies? Anybody know how to identify them? (HumanResource)
What about the sohc zc trannies?
Old Jul 11, 2005 | 11:17 AM
same
all "ZC" cable trannys rund the BIG Diff that requires an intermediate shaft
Old Jul 11, 2005 | 11:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HumanResource &raquo;</TD></TR><TR><TD CLASS="quote">same
i see....so would i need the 1st gen teg axles if i was going to put it in my d16a6?
Old Jul 11, 2005 | 01:20 PM
If you had a junk 88-91 US Civic/CRX inner cup/joint laying around you could use that as a guide (That's what I use)
if it slides in it's small diff and you could use stock 88-91 unequal axles.
if there's slack it's a JDM big Diff- requires 90-93 INTEGRA AXLES AND INTERMEDIATE SHAFT
all kinds of info on the net about taking off the dust plate before installing.
Modified by HumanResource at 2:45 PM 7/11/2005
cpuff
38
Jun 22, 2017 04:55 PM
BrayzieEF9
Jan 23, 2010 04:33 PM
d357r0y
Mar 9, 2004 11:10 AM
VELOCITY R
Nov 8, 2003 06:32 AM
tdc
Feb 13, 2002 01:07 AM
