MY 92 EG WONT START
Old Jul 9, 2005 | 06:53 PM
ooregulateoo's Avatar
Default MY 92 EG WONT START
Hey, I was wondering if you guys knew whats with my car. I Have a 92 eg hatch with a 97 ls motor with 90 k miles on it and it wont start. When i turn on the ignitation it cranks but does not start. I tightended the timing belt got a new starter and got a new battery. Theres a vacume hose thats unplugged and i dunno where that goes and the idle is almost at 0 thats the only problems i know...would u guys know anything about it?
IM me on aim or just repost if you guys have any suggestions
Thanks
Old Jul 9, 2005 | 07:04 PM
DFW's Avatar
DFW
Default Re: MY 92 EG WONT START (ooregulateoo)
Any CEL's?
Old Jul 9, 2005 | 07:10 PM
Archidictus's Avatar
Unceasing Measure
You're obviously new here, so I won't give you ****, but you need to check for spark before going any further. In fact, that should've been the first thing you did before replacing parts that were probably 100% fine. It's probably a main relay or distributor problem as those are our achille's heels as far as normal breakdowns are concerned.
Old Jul 9, 2005 | 07:17 PM
Default Re: MY 92 EG WONT START (Archidictus)
yes i checked the spark plugs and everything looks fine i dont really know what wrong with it
Old Jul 9, 2005 | 07:18 PM
NoahOneill's Avatar
Had the exact same problem today....
Put some gas in it.
Old Jul 9, 2005 | 07:25 PM
Default Re: MY 92 EG WONT START (NoahOneill)
i have a full tank....im just trying to fix this car for i can sell it i checked the spark plugs tightening the timing belt changed the starter new battery it cranks and everything..the only thing i see wrong with it is 1 vacume hose isent connected thats about it
Old Jul 9, 2005 | 07:27 PM
BlueIntegraBoy's Avatar
Main Relay?
Old Jul 9, 2005 | 07:28 PM
Default Re: MY 92 EG WONT START (BlueIntegraBoy)
main relays?
Old Jul 9, 2005 | 07:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ooregulateoo &raquo;</TD></TR><TR><TD CLASS="quote">main relays?</TD></TR></TABLE>
Just one behind your hood latch on the driver side kick panel. It's grey with a brown plug. I know my 92 EG has a hard time starting where it just cranks but doesnt turn. It send power to the ECU for the fuel pump to kick in. What I do when I have trouble is take two fingers and tap hard on the side of the relay and it kicks in.
Old Jul 9, 2005 | 07:52 PM
oh sounds like a plan hopefully it works.....i need this money for my motor swap
sinisdeadly
Nov 7, 2014 03:57 PM
miked123
Jun 16, 2013 04:59 PM
k3nnex
Dec 16, 2010 04:04 PM
