left turn rubbing
Old Jul 9, 2005 | 06:10 PM
george34's Avatar
Default left turn rubbing
the car is a 91 crx hf with a b16 swap, i don't think that matters. when the wheels are turned hard to the left and the car is moving there is a rubbing. the heat sheald was bent back to hopefully fix the problem but it didn't work(rubbing is still there).what do u guys think is the problem??
Old Jul 9, 2005 | 06:11 PM
SiR Inspired ED7's Avatar
Default Re: left turn rubbing (george34)
It's not your rims that are making your tires rub? what size rims/tires u have?
Old Jul 9, 2005 | 06:43 PM
dh's Avatar
dh
Default Re: left turn rubbing (88 Crx Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 Crx Si &raquo;</TD></TR><TR><TD CLASS="quote">It's not your rims that are making your tires rub? what size rims/tires u have?</TD></TR></TABLE>
If it was his rims, it would rub on both sides, wouldn't it?
Maybe you're running too wide of a tire...
Old Jul 9, 2005 | 06:44 PM
george34's Avatar
it is my brothers car. i think the wheels are 15's. i don't know about the tires. could it be a wheel bearing?
Old Jul 9, 2005 | 07:14 PM
dh's Avatar
dh
Well, check what series tires your brother is running. I think that might be the problem.
Old Jul 9, 2005 | 07:31 PM
george34's Avatar
Default Re: left turn rubbing (Master Shake)
i'm just wondering, how would the tire make a rubbing like sound?
Old Jul 9, 2005 | 09:05 PM
dh's Avatar
dh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by george34 &raquo;</TD></TR><TR><TD CLASS="quote"> i'm just wondering, how would the tire make a rubbing like sound?
If your running too wide of a tire, you can rub.
Old Jul 9, 2005 | 11:07 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by george34 &raquo;</TD></TR><TR><TD CLASS="quote">when the wheels are turned hard to the left and the car is moving there is a rubbing.</TD></TR></TABLE>
sounds like a bad wheel bearing.....pop the lower balljoint and pull the axle from the hub then spin the hub. If it sounds like **** or you feel resistance, it's time for a new bearing.
look for heat damage around the axle splines
Modified by eda6 at 5:29 PM 7/10/2005
Old Jul 10, 2005 | 01:26 AM
PinkMaggit's Avatar
Default Re: left turn rubbing (eda6)
i dont get this "rubbing" like rubbing on your fender? you check your fenderwall make sure its not the tires rubbing up on it?
Old Jul 10, 2005 | 02:44 AM
george34's Avatar
Default Re: left turn rubbing (PinkMaggit)
i don't think it is the tire rubbing it sounds more like 2 metal things rubbing. it's hard to say what the noise is like.
Old Jul 10, 2005 | 02:54 AM
dh's Avatar
dh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by george34 &raquo;</TD></TR><TR><TD CLASS="quote">i don't think it is the tire rubbing it sounds more like 2 metal things rubbing. it's hard to say what the noise is like.</TD></TR></TABLE>
Ohhhh I just thought it was a simple problem like your tire rubbing the fender, lol.
Well, I'm thinking it's a wheel bearing like eda6 already said...
I would say your axle, but I don't think it'll make a rubbing sound, more like a clicking one.
Old Jul 10, 2005 | 08:58 AM
b18_crx's Avatar
i had a similar problem and it was my rack........... it vibrated to **** when i held the wheel all the way to the left and also all the way to the right....it sounded like metal grinding/ clunks......oh yeah it happened right after i did my swap for some reason
p0tential
Mar 29, 2008 08:17 AM
latinf86
23
Sep 12, 2006 09:10 PM
TurboEM1
Suspension & Brakes
Nov 14, 2005 03:59 PM
curveit
Nov 2, 2005 02:26 PM
jond
16
Mar 8, 2005 09:12 AM
