Is this the right combo for a throttle body
Old Jul 9, 2005 | 05:22 PM
88 rex's Avatar
Default Is this the right combo for a throttle body
I have a B18c (R) going into my 88dx. All I should need is a 90-93 teg throttle cable, right? I don't think i should need an special bracket since it's a b series bracket.
Old Jul 9, 2005 | 07:20 PM
88 rex's Avatar
Default Re: Is this the right combo for a throttle body (88 rex)
can anyone confirm?
Old Jul 9, 2005 | 07:29 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
No they are not all the same. the distance between the cable bracket and the TB is different depending on the manifold.
if you are going to by a new cable, get an ITR one.
I have just modified the bracket to make it work in the past.
Gte the cable that works with the manifold.
Old Jul 9, 2005 | 07:33 PM
88 rex's Avatar
Default Re: Is this the right combo for a throttle body (The new Spaceballs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The new Spaceballs &raquo;</TD></TR><TR><TD CLASS="quote">No they are not all the same. the distance between the cable bracket and the TB is different depending on the manifold.
thanks
lilo_goki
May 1, 2009 03:01 AM
Crank
Nov 7, 2008 02:30 PM
JDM00SI
Jan 22, 2006 02:06 PM
CNSK
Aug 4, 2004 06:29 AM
