Questions on turbo for prelude 5th gen.
Old Feb 15, 2002 | 11:37 AM
showlude's Avatar
Default Questions on turbo for prelude 5th gen.
I talked to a guy and he said that if i run about 7 psi daily, with a turbo on a stock engine, that my car will only last me a month, i drive on average 25 miles per day, is that true. Plus he said that i wont be able to go on the highway and drive at high speeds like 100+, is that tru too? Please let me know, and also whats the best turbo for my car in order for me to get the best 1/4 times. if you could name some good brands off the stuff you listed and give me an approximate price thatd be great, which turbo would i get the best 1/4 mile, and last the longest with, drag, revhard, or fmax, someone told me those are one of the best.
Old Feb 15, 2002 | 11:38 AM
sgT's Avatar
sgT
Default Re: Questions on turbo for prelude 5th gen. (showlude)
It will last about 6 months. but usually no longer.
5g pistons just crack within that period of time.
Old Feb 15, 2002 | 11:51 AM
FuzzyGreen's Avatar
Default Re: Questions on turbo for prelude 5th gen. (sgT)
sgT are you serious? Why would they crack after 6 months? What if his tuning is perfect?
Old Feb 15, 2002 | 12:04 PM
sgT's Avatar
sgT
Default Re: Questions on turbo for prelude 5th gen. (FuzzyGreenCarpets)
the ring lands on the pistons usually collapse.
Even with perfect tuning i doubt it would last long.
I have seen 15 turbo 5g. each one did the same thing. some were on 6psi some
on 14. No detonation on any of em.
Old Feb 15, 2002 | 12:07 PM
clendaniel's Avatar
errr...speaking on experience I don't think that 7psi is going to hurt. I drove around for >6mos at 10psi and never had a problem until I spiked to 15+...
If you stay on the conservative I really don't think you'll have much trouble but if you get too agressive in your tuning and try to run higher (>9psi or so) boost you will run into trouble. I'd suggest doing your homework and know what you're getting into. For a 5th gen you're primarily looking at drag and fmax for kits...both have their pluses and minuses for which I'm not going to get into. After having gone through it I'd highly suggest starting with a kit w/o any of the fuel mgmt stuff they include and get appropriately sized injectors w/ some type of standalone to control it all...
--Ian
Old Feb 15, 2002 | 01:01 PM
FuzzyGreen's Avatar
Default Re: Questions on turbo for prelude 5th gen. (clendaniel)
Could this have anything to do with the fact that Prelude motors are notorious for burning oil?
Now, I'm worried about my B21! currently running 4psi non-intercooled.
Old Feb 15, 2002 | 01:25 PM
G's Avatar
G
I have had my kit at 8-9psi for several months now. I have had the turbo for more than a year at 7psi+. I broke the ring lands twice, once was a boost control mishap, 16psi and no fuel = piston failure. Next I ordered 40lb injectors and was sent 32lb injectors and found out after a little boosting with the wrong fuel pressures (set up for 40lb ones). Otherwise, good tuning will keep the stockers fine. I did do an 8psi 120mph uphill test in 5th gear to be sure, it was fun and the car is fine as well. Just my experience with a 5th gen turbo.... BTW, my uphill was from 3000rpm to @6000rpm, my car usually leans a bit in those areas, what better way to test and tune than at full load?????
Old Feb 15, 2002 | 02:11 PM
FuzzyGreen's Avatar
Default Re: Questions on turbo for prelude 5th gen. (G)
Damn, did you have any clutch left after that?
Old Feb 15, 2002 | 08:01 PM
showlude's Avatar
Im sorry i need it in more lamens terms, i dont know much about this stuff, the pros and cons of the drag vs fmax would be nice, and what i should get with the turbo if i do run it off a stock engine, and also if i decide to build my engine a little first, what do i get. thanks let me know
honda<4>lyfe
Aug 2, 2013 06:20 AM
H22pwrdhatch's Girl
Nov 21, 2002 09:37 PM
showlude
Feb 17, 2002 08:51 AM
John
Oct 17, 2001 02:57 PM
