can i use a ac comperssor and p/s pump on from a d16 on a b16a2?
Old Jul 9, 2005 | 12:36 PM
RACEPAK's Avatar
Default can i use a ac comperssor and p/s pump on from a d16 on a b16a2?
hello....
i need to know if i can use my ac comperssor and p/s pump from my d16 on a b16 without any modifications of the lines or the mounts?
best regards moshik galimidi
Old Jul 9, 2005 | 12:48 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: can i use a ac comperssor and p/s pump on from a d16 on a b16a2? (RACEPAK)
i know u need A p54 ac bracket, my d series ps pump worked, but the belt fitment wasnt perfect, it works tho
Old Jul 10, 2005 | 07:51 AM
dwnthehatch's Avatar
Default Re: can i use a ac comperssor and p/s pump on from a d16 on a b16a2? (EJ8VTEC)
No.
You WILL need a DOHC vtec del sol ac bracket and the B16 pump.
Old Jul 10, 2005 | 08:05 AM
pdiggitydogg's Avatar
crv ac bracket is cheaper
Old Jul 10, 2005 | 08:54 AM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: can i use a ac comperssor and p/s pump on from a d16 on a b16a2? (dwnthehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch &raquo;</TD></TR><TR><TD CLASS="quote">No.
You WILL need a DOHC vtec del sol ac bracket and the B16 pump. </TD></TR></TABLE>
Depending on the year del sol its either a p30 or p54 bracket, n he is goin to need the p54, or the crv which is cheaper but i dont know the part #... n i am almost positive that i used the d series ps pump cause i know the swap didnt come with one, and i HAVE power steering
Old Jul 10, 2005 | 05:40 PM
RACEPAK's Avatar
can somone give the final answer?
Old Jul 10, 2005 | 09:53 PM
RACEPAK's Avatar
ttt
Old Jul 11, 2005 | 12:44 AM
nyzpapi4u's Avatar
the answer is NO!! i have a B series p/s braket and pump...make an offer
Old Jul 11, 2005 | 04:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
Depending on the year del sol its either a p30 or p54 bracket, n he is goin to need the p54, or the crv which is cheaper but i dont know the part #... n i am almost positive that i used the d series ps pump cause i know the swap didnt come with one, and i HAVE power steering</TD></TR></TABLE>
The crv bracket only works on B16's if you don't use power steering. The only bracket that will work is the del sol VTEC.
The part number is 38930-P54-000 Del Sol ac bracket
RicerBoi16
Apr 22, 2019 06:03 PM
XhaloZ
20
Mar 30, 2014 09:56 AM
jayWknight
Sep 8, 2009 10:28 PM
turbotime
18
Sep 6, 2005 02:48 PM
IMPORTMyth01
Apr 28, 2005 05:23 PM
