6.5's dont fit?
Old Jul 9, 2005 | 11:04 AM
kingrd's Avatar
Default 6.5's dont fit?
thanks all for ure previous help. my new problem (like they end) is that i bought 6.5 soundstream speakers, and they do not fit my car. am i wrong, or do certain spkrs the right size not fit?
Old Jul 9, 2005 | 11:24 AM
.one lane's Avatar
.likes trains
6.5 should fit. is the speaker to "tall"?
Old Jul 9, 2005 | 12:35 PM
95turbogsr's Avatar
Default Re: (Coordinator)
The correct size is 6.5 but if the magnet basket on the back is too big it aint going to fit i know for a fact that 6.5 rockford fosgates wont fit becase there basket is too deep so i went with some sonys with a smaller basket and everything worked fine, check the basket depth i bet that is your problem
Old Jul 9, 2005 | 01:03 PM
sykotic's Avatar
Default Re: 6.5's dont fit? (kingrd)
you can probably make them fit with the use of MDF rings to space them out some more, you have a little of an inch to work with between the door skin and door panel before you will have issues getting the door panel back on.
Old Jul 9, 2005 | 01:33 PM
silva95teg's Avatar
or you can cut the back out of those plastic things in behind the stock speakers and that may also help
Old Jul 9, 2005 | 01:49 PM
.one lane's Avatar
.likes trains
check this out
if you need a lot of depth
click
not that much depth
click
Old Jul 9, 2005 | 05:21 PM
kingrd's Avatar
yea...the front ones are too deep...and the back ones dont fit flush with the car...the diameter is like...slightly too large
Old Jul 9, 2005 | 06:57 PM
cleanDA9's Avatar
Default Re: (kingrd)
is this on a 3rd gen or 2nd gen teg? i have the DA and i put rockford fosgate components in the front and power series in the back and they all fit fine. i had to cram the speaker cover in the rear though, i didn't want the factory speaker covers on there.
Old Jul 9, 2005 | 07:36 PM
cheaphonda's Avatar
Default Re: (cleanDA9)
haha, i had the same problem with my 6.5 in the front. i just cut out the back of the basket like stated above, then the diameter was also a tiny bit too large so i just angled in the screws and taped it up...it works great now
hope this helps
matt
raverx3m's Avatar
can u take pictures?
i have oversized alpines in all 4 and i had to cut my oem speaker holders to fit the new speakers.
Old Jul 9, 2005 | 07:37 PM
solareclipseauto's Avatar
Default Re: (raverx3m)
on the fronts just cut out the basket and you will be fine
PDXHatchback
Mar 18, 2007 05:28 PM
ph0shizzle
Audio / Security / Video
13
Aug 1, 2006 11:32 AM
Unjockable
12
Dec 15, 2003 10:22 AM
onyx00
Sep 6, 2001 11:32 PM
