B20vtec Injectors Question
Old Jul 9, 2005 | 10:11 AM
fracas's Avatar
Default B20vtec Injectors Question
Ok Here is my problem. I have a fully built B20vtec running Rc 310's as of now. I just bought a set of Rc 440's. What I want to know is this. Will the 440's be too much for my set up?
I installed the 440's and it was running So rich that the motor WOULD NOT stay running. I plan on getting tuned this coming week.
97 B20b JDM Block
12:1 Wiseco pistons
Eagle Rods
ACL bearings
Mirco Polished GSR Oil Pump
Knife Edge Crank
Balanced & Blue Printed
GSR Pan & Pick up
ARP head studs & rod bolts
99 B16a2 Head
Full Port and Polish
7 Angle Valve Job
Crower Over size Valves
Crower Springs & Retainers
Skunk2 Stage 1 cams
AEM- Cam Gears, Fuel Rail, FPR, Spark Plug cover
STR cam Seals
Full MSD
DC Sports 4-1 header
AEBS Intake --Polished
Holly 70mm Tb
J's Racing Air Intake
Rc 310cc
Hondata Intake Gaskett
Hondata S200 / P28
Custom EBP Valve cover / Cut for cam gears
Old Jul 9, 2005 | 03:28 PM
fracas's Avatar
Help??????????
Old Jul 9, 2005 | 03:40 PM
5thgenallmotor's Avatar
Default Re: (fracas)
What are you using for engine management? If your just using a stock ecu it will be way rich, most likely... Also what kind of car and do you have the right injectors for your application?
Old Jul 9, 2005 | 03:49 PM
fracas's Avatar
Im not being rude. But did you READ my SET UP LIST???
Man I have a fully BUILT b20vtec. High Compression and Hondata S200 for tuning.
Old Jul 9, 2005 | 04:26 PM
philafelman's Avatar
it looks by your setup that 440's will be ok. ive seen people run 440's with less of a build than that-you should probably get some bigger cams for that compression though.
Old Jul 9, 2005 | 04:37 PM
Sorry man I didn't..... But 440's should be fine... Get it tuned. Do you have a basemap for 440's? Turn the fuel pressure down a little if you can...
Old Jul 9, 2005 | 04:56 PM
fracas's Avatar
so you think Skunk2 stage 2 would be better?
Old Jul 9, 2005 | 09:23 PM
EG6R's Avatar
Default Re: B20vtec Injectors Question (fracas)
whats your worry? you have hondata
Old Jul 9, 2005 | 10:48 PM
dcb16's Avatar
Default Re: B20vtec Injectors Question (EG6R)
it all depends on how much hp you make...
ok.. if you want to do the math to calculate the injector size...
go here... http://www.rceng.com/technical.htm#WORKSHEET
i could give u all the math... but i figured it would be easier to just let u plug and play
Old Jul 9, 2005 | 10:56 PM
dcb16's Avatar
Default Re: B20vtec Injectors Question (dcb16)
oh ya... to guess how much HP you get... to get it in ballpark:
(wheel hp x .15) + wheel hp = estimated bhp (brake horsepower) **i believe you lose 15% to emissions devices and mechanical efficiency but it could be more with certain vaiables**
and your BSFC in your all motor app is about .45
remember 80% is a safe duty cyle for your injector
Old Jul 10, 2005 | 07:36 AM
fracas's Avatar
Great info if I knew what you were talking about.
Old Jul 10, 2005 | 10:57 AM
fracas's Avatar
I looked at the site and tried to use the Graph. But Im lost.
fracas
Dec 15, 2005 12:13 PM
fracas
Texas -OK -LA (Sales)
Dec 15, 2005 06:55 AM
fracas
Jul 12, 2005 05:09 PM
fracas
Jun 25, 2005 06:12 AM
fracas
Jun 16, 2005 02:45 PM
