ACL bearings vs OEM bearings
ok so i want to replace all my bearings, i know OEM would be the right way to go and get all the specific sized bearings. but thats a good 200 bucks in bearings. ACL is nearly half the cost. now would it be ok to use acl bearings rather then sizing for OEM? i mean obviously i dont want the motor to go on me or spin a rod or anything like that. but i also dont wanna pay out the *** for bearings. any input would be great.
Acl makes a really good bearing, if the clearances all spec out the same or very close you can get away with acl as the acls are not available in the different thicknesses that the oem honda bearings are.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 »</TD></TR><TR><TD CLASS="quote">Acl makes a really good bearing, if the clearances all spec out the same or very close you can get away with acl as the acls are not available in the different thicknesses that the oem honda bearings are.</TD></TR></TABLE>
they are avaliable in 2 different sizes, ive heard nothing but good things about these bearings ...thats why im using them in my current build
i used nothing but oem honda bearings in my gsr build..
ACL is what, yellow and green? or pink and green? something like that?
If you find out what your stock bearing color codes are, and if they arent "all over" the chart, and your stock sized bearings were close to the size of the acl's, then id say that would be fine. any way else, i would say no.
Thats in your case.
I go with oem main and rod bearings with the coating on them
Thats in your case.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bosco500 »</TD></TR><TR><TD CLASS="quote">I've used ACL in all of my race motors. Nothing but good things to say.
how do the clearances turn out usualy? ever had to replace a bearing or 2 with OEM because the clearances were off?
</TD></TR></TABLE>how do the clearances turn out usualy? ever had to replace a bearing or 2 with OEM because the clearances were off?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRCRXsi »</TD></TR><TR><TD CLASS="quote">how do the clearances turn out usualy? ever had to replace a bearing or 2 with OEM because the clearances were off?</TD></TR></TABLE>
They have always come within specs on everything I have done. But there WILL be a case here and there where you will have to buy an OEM bearing or two.
hmtcrxsir
Jun 7, 2009 01:42 AM
