ECU Casings/Mounting
Old Feb 15, 2002 | 10:04 AM
Aron Parsons's Avatar
Default ECU Casings/Mounting
I just put an 89 Teg ECU into my 90 CRX. I mounted it using some screws, so it is secure, but the plate that goes over it won't bolt down (not even one or two bolts). I'm a little uneasy about leaving it uncovered, I might have a stuipd friend put his feet down real hard. Is there a way to get it to fit? Or I was also thinking of changing the circuit boards between cases (putting the Teg ECU board into the Si case), that way it would mount. Is that possible? ( I know if I do that, I won't be able to see the LED, but that can be fixed too). Any input? Thanks.
Old Feb 15, 2002 | 10:46 AM
keithv's Avatar
Default Re: ECU Casings/Mounting (OvERaCiD)
mount the teg board in the si case and drill a hole in the case where the teg led is.
viola.
Old Feb 15, 2002 | 11:02 AM
wronghand's Avatar
I have an 88 DX and the teg board would not fit in my casing. I cut one of the mounting arms off the teg case so the cover would fit over it. I also drilled a hole in the case as well as the cover so I could see the LED. One final thing, I secured the ECU to the cover with some strong velcro to keep it from sliding around under the cover.
HTH
Old Feb 15, 2002 | 05:16 PM
Giuseppe's Avatar
Default Re: ECU Casings/Mounting (breaka_1_9)
viola.
not happening.. try an 87 teg case if u can find one.. it works too
just drill out a hole...voila
Old Feb 15, 2002 | 05:42 PM
markedOO1's Avatar
Default Re: ECU Casings/Mounting (Giuseppe)
not happening..
it certainly does! I've done this like 4 times w/ si ecu's...the boards are the exact same size and have all the same mounting points...
Old Feb 15, 2002 | 06:47 PM
Giuseppe's Avatar
Default Re: ECU Casings/Mounting (marked001)
i tried putting a 89 teg ecu in a 90dx case and
it would not fit.!!
the teg board is shorter.!!! and the bolt holes were off
if u claim its true the dx and si boards are different
and its my bad.!
Old Feb 16, 2002 | 06:13 AM
markedOO1's Avatar
it makes sense that the dx boards/cases would be different....so its just the si (hf maybe) case...
Old Feb 19, 2002 | 07:41 AM
keithv's Avatar
it would not fit.!!
and its my bad.!
i had an si case and put an 89 teg board in it...
so i think we are all on the same page now. only an si case will accept an 89 teg board.
drjondurst
17
Apr 4, 2003 11:00 PM
pdiddyparsons
Mar 22, 2003 10:08 AM
CWBETB
Mar 10, 2003 11:46 AM
Red_Si
Aug 7, 2002 08:28 PM
Red_Si
Jul 11, 2002 07:34 AM
