trying to pull the clutch; but trans won't come off
Old Jul 8, 2005 | 07:26 PM
Ls91sI's Avatar
Default trying to pull the clutch; but trans won't come off
can anyone help me with any ideas or tips on how to pull the trans apart from the block. i can't seem to pull the trans all the way off, it is off about half an inch but won't budge any farther. The entire motor is out, if that helps.
any info would be a huge amount of help..................thanks
Old Jul 8, 2005 | 07:57 PM
spidermancivic's Avatar
Default Re: trying to pull the clutch; but trans won't come off (Ls91sI)
if i can do it myself, so can you. its a bitch sometimes, but, lay a wheeled jack under the tranny and use more muscle.
Old Jul 8, 2005 | 08:16 PM
cdx280's Avatar
just yesterday i finished installing a new clutch in my 90 civic dx. this was the first clutch i've done so it taught me alot. when takin the trans off the engine block, i used a jack underneath it so that once it did come loose it wouldnt drop to the ground (duh). it took a little prying cuz there was so much grease and crap covering basically everything under the hood. you just need to use a lil muscle and pry it off.
good luck
Old Jul 8, 2005 | 08:29 PM
PrettyLude's Avatar
a prybar and patience will do it
Old Jul 8, 2005 | 09:15 PM
UNKNOWN_MEMBER's Avatar
dont forget to take out the starter.
Old Jul 13, 2005 | 06:11 PM
Ls91sI's Avatar
thanks a lot. i'll give you the heads up as soon as it comes off
Old Jul 14, 2005 | 01:35 AM
Default Re: (Ls91sI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls91sI &raquo;</TD></TR><TR><TD CLASS="quote">thanks a lot. i'll give you the heads up as soon as it comes off
</TD></TR></TABLE>dont forget the shield on the bottom also.
MissNik
12
Aug 6, 2013 07:58 AM
okcdc2
Jan 14, 2012 11:37 PM
jbrokos307
Mid-Atlantic (Sales)
Nov 2, 2009 07:43 AM
5pointSlowkilla
Transmission & Drivetrain
Feb 6, 2009 10:06 AM
Fleas_Ef
14
Jan 26, 2005 06:52 PM
