DIY Homemade Catch can
Hey guys just wanted to post up my new catch can that I finshed fabbing up today for under $20. It looks pretty sick just like it was store bought or manufactured. so hit me up with some comments to see what you guys think.
During the grinding
After grinding
Sanding
After sanding
Polished
Side by side comparison
Size comparison
Install
During the grinding
After grinding
Sanding
After sanding
Polished
Size comparison
Install
Alummized steel, maybe mild i dont know if they are rhe same
there is like steel wool as fine as a brillo pad inside and you can see the drain plug perpendicular of the air hose fittings on the bottom
1st picture the end where he grinding is the bottom
thanks for the comments
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxguy05sir »</TD></TR><TR><TD CLASS="quote">Alummized steel, maybe mild i dont know if they are rhe same
thanks for the comments</TD></TR></TABLE>
Alumnized steel is mild steel, just coated so it don't rust. Really hope you are grinding it away though, just read about an older welder that passed from getting poison from the galvanized coating on there
